Interfacing Teensy 4.0's CAN controller with a CAN transceiver for BLDC Actuator
Hey guys,
I have recently bought a BLDC actuator that uses CAN communication. Its working perfectly fine using an MCP2515 CAN module with an Arduino Mega. However, due to my application, I require it to work with Teensy 4.0 as it has a greater computational power.
Since Teensy 4.0 has a built in CAN controller therefore, I decided to use THREE different CAN transceiver modules with it ( including TJA1050, MCP2551 and SNHVD230 ) . Unfortunately, I have been unable to make the motor run. The motor uses an MIT mini cheetah driver which requires a certain command to enable its motor mode. Thats all I have been trying to implement using teensy so far, not even anything complex.
Could someone please help me out?
The pin configuration for Teensy 4.0 with SN65hvd230 is mentioned below:
CAN transceiver VCC -----> 3V on Teensy 4.0
GND--->GND on the Teensy.
CAN TX (D): Connected to the Teensy's CAN TX pin, which is pin 22.
CAN RX (R): Connected to the Teensy's CAN RX pin, which is pin 23.
CANH and CANL of tranceiver connected to the CANH/CANL of the motor.
Im using FlexCAN_T4 library. And the code is as mentioned below:
#include <FlexCAN_T4.h>
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> can1;
while (!Serial);
can1.begin();
can1.setBaudRate(1000000); // Set baud rate to 1Mbps(motor requirement)
Serial.println("CAN bus initialized.");
CAN_message_t msg;
// Define the message
msg.id = 0x00B; // CAN ID
msg.len = 8; // Data length code (8 bytes)
msg.buf[0] = 0xFF;
msg.buf[1] = 0xFF;
msg.buf[2] = 0xFF;
msg.buf[3] = 0xFF;
msg.buf[4] = 0xFF;
msg.buf[5] = 0xFF;
msg.buf[6] = 0xFF;
msg.buf[7] = 0xFC;
// Send the message
if (can1.write(msg)) {
Serial.println("Message sent successfully");
Serial.println("Error sending message");
delay(1000); // Wait for 1s
Please help me out. Its very important
Those are 5v chips. Did you power them with 5v? If so the Teensy Rx pin may be damaged.
Do you have an oscilloscope?
Yes sir, I have tried 5V too. I bought 3 of each kind to experiment. Including a spare teensy. Tried it on both using all combinations. Its really weird.
