Interfacing the YM2149 with an Arduino Mega Code
Good Morning Gents, I'm stuck for 2 months on this project and I'm about to drop it...
So, I read the manual of the PSG and i did everything right but it does not work.
The setup is the following:
1 x 2Mhz resonator (working fine);
1 x SN74HC595N
1 x arduino mega 2560
1 x Ym2149
The shift register is connected to the arduino and to de PSG.
Here is the pinout: (available in the code as well)
PSG
D0->D7 -> Shift Register QA->QH
BCDIR/BC1 -> Arduino Mega PORTA (pins 22/23)
BC2 -> +5V
Audio out A, B, and C are each one connected to a 1k ohm resistor and them connected to the output which is connected to ground with a 100 ohm resistor
I used another code (not mine) and the PSG works fine but I can't understand it.
So the chip is not the problem nor the shift register.
Hope some of you experienced Gents will be able to help me!
Here is my code Btw:
//COMMANDS
// Digital pins output to YM2149F
int D0 = 37;
int D1 = 36;
int D2 = 35;
int D3 = 34;
int D4 = 33;
int D5 = 32;
int D6 = 31;
int D7 = 30;
//Address/reg select
int BDIR = 23;
int BC1 = 22;
//shift Registor
int data = 8;
int latch = 9;
int CLK= 10;
//Variables
int i = 0;
int l = 0;
int t = 0;
int Freq = 0;
int x = 0;
int test_n = 0;
//void data
int FB;
int LB;
#define Master_Clock  2000000;
//Automation Arrays
int testex [] = {1,2,4,8,16,32,64,128}; // not in use
int D_Output [] = {D0,D1,D2,D3,D4,D5,D6,D7,BDIR,BC1, data , CLK , latch};
int D_Output_n = 0;
void setup() {  // Pin Config
  while  ( D_Output_n < 13) {
    pinMode ( D_Output [D_Output_n] , OUTPUT);
    D_Output_n++;
 Serial.begin (9600);
 Serial.println ("Codename *hidden*  started");
 delay (100);
 D_Output_n = 0;
  // DDRC = B11111111;
// GOLDEN RULE
Freq = Master_Clock / TP * 16;
void Address_mode(){
  PORTA = B00000011;
  delay(x);
void Inactive_mode(){
  PORTA = B00000000;
  delay(x);
void Write_mode() {
  Latch();
  PORTA = B00000010;
void mixer_EA(){ //corrected
 Address_mode();
 shiftOut (data ,CLK ,LSBFIRST, 6); //reg 7
 Latch();
 Inactive_mode();
 shiftOut (data ,CLK ,LSBFIRST, B11111000); //Only melodical voices / io ports and noise off | IOB | IOA | Noise A | B | C | Sound A | B | C |
 Write_mode();
 Address_mode();
 shiftOut (data ,CLK ,LSBFIRST, 7); //reg 8  Channel A Volume
 Latch();
 Inactive_mode();
 shiftOut (data ,CLK ,LSBFIRST, B00001111);
 Write_mode();
 Inactive_mode();
void Clean(){
 // shiftOut(data, CLK, LSBFIRST , 0); not in use
void Latch(){ //shift register latch
  digitalWrite (latch , LOW);
  digitalWrite (latch , HIGH);
/*                                                 xxxxxxx
 * ADDRESS MODE: BDIR=HIGH / BC1 = HIGH -> PORTA = B00000011
 * WRITE MODE  : BDIR= HIGH / BC1 = LOW -> PORTA = B00000010->BC1
 *                                                        BDIR
void Wave_s (){ //corrected | wave type
 Address_mode();
 shiftOut (data , CLK , LSBFIRST , 13); //Reg 13
 Latch();
 Inactive_mode();
 shiftOut (data, CLK , LSBFIRST , B00001011); // square wave
 Write_mode();
 Inactive_mode();
void Channel_A ( int FB , int LB) { //corrected | not in use
  Address_mode();
  shiftOut(data, CLK, LSBFIRST , 6);
  Latch();
  Inactive_mode();
   shiftOut(data, CLK, LSBFIRST , FB);
  Write_mode();
  Inactive_mode();
   Address_mode();
   shiftOut (data, CLK, LSBFIRST , 7);
   Latch();
   shiftOut (data, CLK, LSBFIRST , LB);
   Write_mode();
   Inactive_mode();
//PORTX = B76543210 ->
Inactive_mode(); //Resets Bus Control
   Address_mode();
   shiftOut(data, CLK, LSBFIRST , 6);//Address 7
   Latch();
   Inactive_mode();
  shiftOut(data, CLK, LSBFIRST , B11000000); //reg 7 | config channels
  Write_mode();
  Inactive_mode();
  Address_mode();
  shiftOut (data, CLK, LSBFIRST , 7);//Address 8
  Latch();
  Inactive_mode();
  shiftOut (data, CLK, LSBFIRST , B00011111); //reg 8 | config volume channel A
  Write_mode();
  Inactive_mode();
  Wave_s(); //sets up Square Wave
  Address_mode();
   shiftOut(data, CLK, LSBFIRST , 0);//Address 1
   Latch();
   Inactive_mode();
  shiftOut(data, CLK, LSBFIRST , B00000111); //sets fine tone channel A
  Write_mode();
  Inactive_mode();
  Address_mode();
  shiftOut(data, CLK, LSBFIRST , 1); // Address 2
  Latch();
  Inactive_mode();
  shiftOut(data, CLK, LSBFIRST , B00000001); //sets rought tone channel A
  Write_mode();
  Inactive_mode();
  delay (100);
I don't know if the program is running way to fast and the PSG isn't catching up or the order of the registers are wrong ...
The program only asks the PSG to generate one tone for testing but it does nothing.
Edit: the Shift register was added because for some reason all ports of my arduino mega had a problem where 3 or 4 outputs would not work (I'm thinking in replacing this board...).
