Hello, first time on the Arduino so please bear with me.
I am attempting a project in which I would like to interface with:
an XPort - to grab time via NTP from nist.gov (like the 3 Meter project)
a Maxim DS1306 Real Time Clock - to store the time received by the Xport and provide interrupts to the Arduino to write the time to a
Maxim 7219 to display the time form the RTC on six 7-segment LED displays.
I'm trying to graft this project together from three separate projects, each using the above components, however I'm running into a little trouble understanding how to set up the code to communicate with all three. For instance, all three projects use serial.begin, but different speeds. Is there a (relatively) simple way to do this? Two software serials and a hardware serial?
Maxim 7129 to display the time form the RTC on six 7-segment LED displays.
I have no idea how to interface from the arduino to he XPort, but the DS1306 does not use or need a Serial-line, it is driven via SPI
which something completely different.
I guess the MAX7229 was a typo, and you meant a MAX7219?
The 7219 also uses SPI and there is already some information how to drive 7-segment LED-Displays with it : http://www.arduino.cc/playground/Main/LedControl
So the serial-line is free for the xport to use.
Of course! Now it makes more sense. And I believe the Xport uses a software serial, so even with all three I'm still not using the hardware serial. I think where I got confused were the multiple serial.begin() commands, but on closer inspection, it looks like all three projects were using the hardware serial to spit results out to a computer... I guess I don't need multiple serial.begin commands afterall. Thanks!
