Hi all,
Im not sure if this is the right forum, but it seemed to be the closest match.
I want to interface an Arduino with a PT1000 RTD temperature sensor. My range of interest is 85C to 95C which corresponds to 1328 Ohms to 1366 Ohms.
I have breadboarded a circuit and am using a 25 ohm variable resistor to roughly simulate the RTD sensor.
So, I am reading the "sensor" value, performing an operation on it to get the range of values I am interested in and serially outputting to my pc. And its working.....
But I am getting only integer values, whereas I really want 0.1 resolution.
Is it possible to do this with the serial output?
Later I will be also interfacing with a LCD, so maybe I can only do it on the LCD?
Here is my code....
RTD Analog Input
This will read the value of RTD/POT, save it as
a variable, then calculate the temp
The circuit:
* Wheatstone bridge feeds diff amp attached to analog input 0
int sensorValue = 0; // variable to store the value coming from the sensor
int tempValue = 0; // variable to store calculated temp
// read the value from the sensor:
int sensorValue = analogRead(0);
tempValue = ((sensorValue-225)/54)+85;
Serial.println(tempValue);
delay(10);
You're being bitten by "integer division". In C++ 150/54 (for example) is 2. Not 2.777 or 2.8 but just 2. So your expression ((sensorValue-225)/54) loses a lot of precision.
You can try using floats or doubles to work with real numbers prior to converting back to an integer:
tempValue = ((sensorValue-225.0)/54)+85;
Adding a real number forces real-number computation, and the final result is converted back to an integer when you write the result to tempValue.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Yes, it's best to stick to integer numbers whenever possible as floating-point computation takes quite a bit more work (time). Just computing 10 times the needed quantity and displaying it on an LCD with the decimal point in the right place is the way to go.
The Quick Shield: breakout all 28 pins to quick-connect terminals
