Interfacing with a 4D systems display via I2C
Hi there,
I am trying to connect an arduino to a 4D display using the I2C bus because the serial port is in use. I want the arduino to collect analog sensor data and store that data until the 4D display is ready to request it.
I have been trying every combination that i can think off, looking at the reference manuals of both devices and the best i can get is getting the 4D device to request a string from the arduino and the arduino to send it.
I can't get it to send an integer, and i can't get it to send multiple sensor values.
below is the working code:
Arduino:
#include <Wire.h>
String data = "test";
  Wire.begin(4);                // join i2c bus with address #2
  Wire.onRequest(requestEvent); // register event
void requestEvent()
Wire.write(data.c_str());
4DGL code:
#platform "uVGA-III"
var buffer[4];
func main()
     I2C_Open(I2C_FAST);
 repeat
     I2C_Idle();
     I2C_Start();                // Generate Start condition
     I2C_Write(0x09);            // send slave address, R/W bit is 1
     I2C_Idle();
     I2C_Gets(buffer,4);
     I2C_Nack();                 // finished reading, send Not Ack
     I2C_Stop();                 // finished with bus
     print("\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n","\n");
     print("received: ",[STR]buffer);
     gfx_Cls();                      // clear screen and do it forever
forever
endfunc
does anyone know how i could do this? because the Picasso chip on the 4D device doesn't have any analog inputs, i need effectively an analog to I2C device, but i want to do this with the arduino because then i can do some preprocessing on the sensor data and free the screen up for just refreshing.
any help would be great thanks!
That is ALL you need to accomplish. Convert the int to a string - not a String. The write() method is overloaded. Use the two argument method that includes the length of the array.
P.S. itoa() would be useful.
