I have been trying to find a solution to integrate my electronic dartboard to a PC. It seems the arduino might be it. I am a software person, so I am looking for help with the hardware.
The dartboard works like an 8x8 keypad matrix. Two films sandwich a thin separator. Take a look at the pictures here.
That dartboard uses an 8x11, mine uses an 8x8 matrix.
I saw a circuit for this sometime ago. From what I understand is I would set 8 pins to high with the pull up resistor, they would get the top film. The bottom film would hook up to 8 pins that are set to low. When a dart hits it should create an interrupt and then I would need to poll the pins. So when I do this for the pins set to high I would be looking for the low, correct? Visa versa on the other side?
Now, there is the question about having enough pins. I know the common arduino has 14 digital pins and 6 analogs that can work like digital. If I hook up the arduino through usb does that only take up 2 of the pins?
