Interfacing with a TDA1543 I2S 16-Bit DAC
Has anyone interfaced with a TDA1543 I2S 16-Bit DAC?
I was happy finding this device, because it looked like a cheap 16-Bit DAC, but it works with I2S, not I2C (so forget about the Wire library).
Looking at the datasheet (Philips TDA1543 datasheet pdf) it does look quite simple, but since i'm a rookie interfacing with this devices, I'm sure I'm missing something big.
The max frecuency is 9,2MHz, but since there is no minimum, I'm not afraid. The signal times are all minimums, and I'm sure Arduino is slower than that.
What else am I missing?
Regards
