My problem is using the Arduino as the signal source. If I send a PWM signal (using analogWrite) it controls the brightness of all the LEDs, instead of controlling how many are turned on. If I replace the Arduino with a pot hooked on a 5v source, the chip behaves as it should. Is this a current issue?
Some time ago I was working on the same LM3914 circuit and trying to make it work using PWM and a R/C circuit with my Arduino but it never quite worked right .
I finally opted for using a digital pot connected to 5V and feeding the wiper pin to the input of the LM3914. The digital pot was controlled by the Arduino. I had better control of which light would light up.
Graynomad and Richard Crowley; You guys are both right but in my own defence I did it as a way of experimenting and exploration of adapting a known circuit for automation using the Arduino.
In the final phase I did use a much more efficient method of controlling the LED's without using the LM's but the knowledge I got experimenting and understanding digital interfacing drove me to start thinking of new possibilities for newer projects.
I think that we all need to take baby steps before we can run
Got around to wiring the Low pass up and the values of 1K and .001uF didn't help. The circuit did work however when I went to 10K and 1uF. It might have something to do with my resistor values on Pin 7 and 8 of the chip, as mine are not exactly the same as the diagram.
