interfacing with multiple 4021b IC's
greetings,
i’m doing a project wich involves getting user input from a typewriter, and to do so, i’ve followed the tutorial for the shiftin wich is in the main website. i’ve managed to get the data for 5 4021b (i’ll be needing 6, but i haven’t got time to buy the 6th, so i am working with 5) and it all works great, i can get the info i need, yet i get a 1 to 1,5 seconds delay. any method to reduce the delay? or any other way to get what i want without such a noticeable delay?
this is the code i’ve got
int latchPin = 8;
int dataPin = 9;
int clockPin = 7;
byte switchVar1 = 0;
byte switchVar2 = 0;
byte switchVar3 = 0;
byte switchVar4 = 0;
byte switchVar5 = 0;
//start serial
//define pin modes
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, INPUT);
void loop(){
digitalWrite(latchPin,1);
delayMicroseconds(20);
digitalWrite(latchPin, 0);
switchVar1 = shiftIn(dataPin, clockPin);
switchVar2 = shiftIn(dataPin, clockPin);
switchVar3 = shiftIn(dataPin, clockPin);
switchVar4 = shiftIn(dataPin, clockPin);
switchVar5 = shiftIn(dataPin, clockPin);
Serial.println(switchVar1, BIN);
Serial.println(switchVar2, BIN);
Serial.println(switchVar3, BIN);
Serial.println(switchVar4, BIN);
Serial.println(switchVar5, BIN);
delay(10);
byte shiftIn(int myDataPin, int myClockPin){
int i;
int temp = 0;
int pinState;
byte myDataIn = 0;
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, INPUT);
for(i = 7; i>= 0; i–){
digitalWrite(myClockPin, 0);
delayMicroseconds(0.2);
temp = digitalRead(myDataPin);
if(temp){
pinState = 1;
myDataIn = myDataIn | (1<< i);
pinState = 0;
digitalWrite(myClockPin, 1);
return myDataIn;
many thanks
Bruno Gustavo Costa
I don't know if this is ýour problem, but you are using 0.2 as a patameter to delayMicroseconds.
This is probably not a good idea.
Read here : http://www.arduino.cc/en/Reference/DelayMicroseconds
thank you for the quick reply. will try changing that as soon as possible
worked perfectly
cool
