Interfacing with SPI
I am trying to interface two arduino boards together with this RF Link - http://www.rfsolutions.co.uk/acatalog/Alpha_TRX_Modules.html
The interface for this RF link is SPI, however looking at the data sheet from RS Components for the Arduino UNO it says
“SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK). These pins support SPI communication, which,
although provided by the underlying hardware, is not currently included in the Arduino language.”
How would i go about interfacing the two together?
Regards
Tris
That is wrong.
http://arduino.cc/en/Main/ArduinoBoardUno
SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK). These pins support SPI communication using the SPI library.
Now, the Mini, on the other hand: http://arduino.cc/en/Main/ArduinoBoardNano
SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK). These pins support SPI communication, which, although provided by the underlying hardware, is not currently included in the Arduino language.
So, the simple solution is to not get the Mini for your project.
I'd also steer clear of RS Components.
Hi Paul
Thanks for the swift reply!
Im guessing that to link the RF link and board to send and revieve data a case of plugging the components together via the SPI ports and then setting up the programming to send and recieve the data via these ports?
I appologise for the simple and basic questions but my knowledge of programming and interfacing is very very limited.
Regards
Tris
Yes at it's simplest level it is. However the protocol you have to implement is perhaps more of a challenge to you. Get the data sheets, read them, understand them, before parting with cash. If there is something you don 't understand, find out, it will not sort itself out.
