Interfacing with the NRF24L01+ and a Micro SD Card
I hate to post about this issue again since I know it has been convered so much in other posts. I have an NRF24L01+ and a microSD card. I would like to use them together.
From reading other posts, I changed the microSD card module so that the MISO lines does not go through the level shifter. I have also added a 1K resistor in series with the SD card MISO line.
In my code, I start with the SDSetup();
void SDSetup() {
    SDDetect = SD.begin(csSD);
    if (SDDetect) {
      logFile = SD.open("Log0001.txt", FILE_WRITE);
      logFile.println("Time, Voltage, Altitude, Acceleration, Roll, Pitch, Yaw, Latitude, Longitude");
      logFile.close();
This section works and writes a file. I then setup the NRF.
void nrfSetup () {
  radio.begin();
  radio.setChannel(108);
  radio.setDataRate(RF24_250KBPS);
  radio.setPALevel(RF24_PA_MAX);
  radio.enableAckPayload();
  radio.setRetries(7,5);
  radio.openWritingPipe(slaveAddress);
This code works as well. I then do the NRF loop.
void nrfLoop() {
    if (radio.write( &myData, sizeof(myData) )) {
        if ( radio.isAckPayloadAvailable() ) {
            radio.read(&myTele, sizeof(myTele));
The issue is when I try to do a SD card loop.
void SDLoop() {
  Serial.println(logFile);
  if (logFile) {
    logFile.print(X1); logFile.print(","); logFile.println(Y1);
  logFile.close();
With the following code and setup, the SD card creates a file and writes the header text. The NRF gets setup and starts transmitting. The NRF works well and doesn't miss a beat the whole time I have the code running. My issue is that the SD card loop is not working. When I disable the NRF loop and setup code, the SD card loop works perfectly and writes to the SD card.
Is there something I have to do with the chip selects that the libraries aren't automatically doing. I am using the standard SD card library and the RF24 library.
Update: Screwing around with the code more I realized that even with the NRF unplugged from the Arudino, running the NRFSetup() code will cause the SD Loop not to work. So now I am thinking it is something to do with the NRF code interfering with the SD card?
