Interference from Stepper Driver
Hi. I'm trying to solve a problem with my setup.
What I have are:
A3967 V4.4 EasyDriver Stepper Motor driver
NEMA 17 stepper motor
I2c LCD
4x4 keypad membrane
The modules are all working fine except for the random Keypad read that occurs whenever the stepper driver is turned on (even without having to drive the stepper motor).
I dont have the connections/code rn but rest assured that all of it are correct. Worth noting is that the stepper driver is powered by a 12v psu while the arduino is powered through its usb 5v port. All components are connected directly to arduino mega through a mega expansion board shield using male/female etc wires.
Also worth noting is that the "random" reads doesn't occur when I disconnect the digital signal pins for the stepper driver. My guess is that interference occur within the driver which affects the inputs in my mcu.
Thank you in advance
Well, I for one will rest assured.
Your code and connections may be correct, but perhaps they're incomplete or inadequate.
Devspacito:
We have heard that many times before.
Just post your program and a photo of a simple pencil drawing showing how YOU have everything connected.
A photo of your project would also be useful in case the problem is due to cross-talk between wires. NOTE that this photo is not a substitute for the drawing of the connections.
...R
Simple Image Posting Guide
Stepper Motor Basics
Simple Stepper Code
The code doesn't look very professional and there are still some fixing to function properly. Anyways the main concern is the interference part occurs when the motor driver is powered.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6, 7, 8, 9}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
bool flagVal1 = 0, flagVal2 = 0;
int val1 = 0; //VTBI Temp name
int val2 = 0;
int val3 = 0; //rename later on
//LCD Menu Logic
const int numOfScreens = 3;
int currentScreen = 0;
String screens[numOfScreens]= {{"VTBI INPUT"}, {"Drop something man"},
{"Press X to Stop"}};
  lcd.init();                      // initialize the lcd
  lcd.init();
  lcd.backlight();
  vtbiCheck();
  dripChk();
  if(flagVal1==1&&flagVal2==1){
    char c;
    Serial.println("wew");
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(screens[2]);
    lcd.setCursor(0,1);
    lcd.print("Drop Rate"); //display yung value na needed
    do{
      c = customKeypad.getKey();
      }while(c!='C');
void vtbiCheck(){
  char c;
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(screens[0]);
  do{
    if(c=='*'||c=='#'){
      Serial.println("invalid input");
      clearLine(0,1);
      lcd.setCursor(2,1);
      lcd.print("INVALID INPUT");
      delay(1500);
      clearLine(0,1);
     else if(c=='A'){
      //increment ml
      val1 = val1 + 100;
      clearLine(0,1);
      lcd.print(val1); // print line here
      lcd.print(" ml");
      Serial.println("hey");
      else if (c=='B'){
      //decrement value of ml
      val1 = val1 - 100;
      clearLine(0,1);
      lcd.print(val1);
      lcd.print(" ml");
      Serial.println("hey1");
      else if(c=='D'||c=='C'){
      else{
      //output value of ml
      if(c!=NO_KEY){
        val1 = c - '0';
        val1 = val1*100;
        clearLine(0,1);
        lcd.print(val1);
        lcd.print(" ml");
        Serial.println("hey2");
    }while(true);
    if(c=='C'){
      flagVal1 = 0;
      val1 = 0;
      Serial.println("Cancelled");
    if(val1<=0||val1>1000){
      flagVal1 = 0;
      Serial.println("Out of bounds");
    else{
      flagVal1 = 1;
      Serial.println("Success");
void dripChk(){
  char c;
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(screens[1]);
  do{
    if(c=='*'||c=='#'||c=='6'||c=='7'||c=='8'||c=='9'||c=='0'){
      clearLine(0,1);
      lcd.setCursor(2,1);
      delay(1500);
      clearLine(0,1);
     else if(c=='A'){
      //increment ml
      val2 = val2 + 40;
      clearLine(0,1);
      lcd.print(val2); // print line here
      lcd.print(" drops/hr"); //recheck
      else if (c=='B'){
      val2 = val2 - 40;
      clearLine(0,1);
      lcd.print(val2);
      lcd.print(" drops/hr"); //check
      Serial.println("hey1"); //all serial prints for checking only
      else{
      if(c!=NO_KEY){
        val2 = c - '0';
        val2 = val2*40;
        clearLine(0,1);
        lcd.print(val2);
    }while(true);
    if(c=='C'){
      flagVal2 = 0;
      val2 = 0;
    if(val2<=0||val1>200){
      flagVal2 = 0;
    else{
      flagVal2 = 2;
void pump(){
//stepper
void clearLine(int a, int b){
  lcd.setCursor(a,b);
  lcd.print("                ");
  lcd.setCursor(2,1);
The code is not the current version that I am using bc its with my classmate but Im telling you, the connections and the code is fine. The project is already functioning well since all codes are direct copies from the library.
The only problem is the random keypad reads (which is connected at pins 22-29) whenever the stepper driver is powered. We've originally used a tb6600 stepper driver but the manual dip switch control for the microstepping is a problem. Originally, the random key problem doesn't occur since (from what Ive searched) the tb6600 is isolated with optocouplers.
Ive searched ground loops interference, power supply coupling and etc etc but none has worked for me so far. I twisted the wires of the stepper motor in pair, placed some variety of capacitor to the 12v supply (i tried series, parallel).
If anyone asks, I'm making an Infusion pump.
And yes, my sketch didn't help i know. Lastly, please bare my english.
Images from Reply #3 so we don't have to download them. I already gave you a link to the instructions for this.
...R
You need to make a much more detailed connection diagram showing all the wires and with all the pins labelled so we can tell if there is a wiring error.
Then wait until you have the latest version before posting. It's a complete waste of time looking at yesterday's code.
Help us to help you.
...R
Hello again. I finally met with my classmates and had a better shot for the connections.
Anyways, the current code we are using is this one
#define xbeeCon; Serial1
#define airPin A2
#include <AH_EasyDriver.h>
//AH_EasyDriver(int RES, int DIR, int STEP, int MS1, int MS2, int SLP);
AH_EasyDriver stepper(200,4,5,2,6,3);    // init w/o "enable" and "reset" functions
const int lockPump = 9;
#include <Keypad.h>
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {29, 28, 27, 26}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {25, 24, 23, 22}; //connect to the column pinouts of the keypad
bool flagVal1 = false, flagVal2 = false;
int val1 = 1; //VTBI Temp name
int val2 = 0;
//LCD Menu Logic
String screens[4]= {{"VTBI Input"}, {"Rate ml/hr Input"}, {"Press -> to Start"},
unsigned long startTime, flowTime, totTime, delayTime;
//#include "hx711.h"
//Hx711 scale(A1, A0);
  lcd.init();
  lcd.backlight();
  xbeeCon.begin(9600);
  //pinMode(rst_pin, OUTPUT);
  //digitalWrite(rst_pin,HIGH);
  xbeeCon.println("Hello XBEE GENSAN");
  delay(50);
  pinMode (lockPump, INPUT);
  pinMode(airPin, INPUT);
  stepper.sleepOFF();
  vtbiCheck();
  dripChk();
    char c;
    lcd.setCursor(0,0);
    lcd.print("Press > to Start"); //display yung value na needed
    while(customKeypad.getKey()!='D'){}
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(screens[3]);
    startTime = millis();
    do{
      pumpGo();
      if(airCheck()){
        Serial.println("www");
        pumpStop();
        flowTime = millis() - startTime;
        //startTime = startTime + millis();
        totTime = totTime - flowTime;
        transmitXbee(1);
        //while(customKeypad.getKey()!='D'){
      if(loadCheck()){
        pumpStop();
        Serial.println("load");
       // startTime = startTime + millis();
        transmitXbee(2);
      delayTime = millis();
      /*do{
        if(customKeypad.getKey()){
        Serial.println(c);
        }while(millis()-delayTime<1000);*/
      Serial.println(millis()-startTime);
      }while(c!='C'&&(millis()-startTime<5000));
void vtbiCheck(){
  char c;
  lcd.clear();
  lcd.setCursor(0,0);
  do{
    if(c=='*'||c=='#'||c=='0'){
      clearLine(0,1);
      lcd.setCursor(2,1);
      clearLine(0,1);
      val1 = 0;
     else if(c=='A'){
      //increment ml
      val1 = val1 + 100;
      clearLine(0,1);
      lcd.print(" ml");
      else if (c=='B'){
      val1 = val1 - 100;
      clearLine(0,1);
      lcd.print(val1);
      lcd.print(" ml");
      else{
      if(c!=NO_KEY){
        val1 = c - '0';
        val1 = val1*100;
        clearLine(0,1);
        lcd.print(val1);
        lcd.print(" ml");
    }while(true);
    if(c=='C'){
      flagVal1 = false;
      val1 = 0;
      flagVal1 = false;
    else{
      flagVal1 = true;
void dripChk(){
  char c;
  int temp = 1;
  lcd.clear();
  lcd.setCursor(0,0);
  clearLine(0,1);
  lcd.print("5 drop(s)/min");
  do{
    if(c==NO_KEY){
       //No input
    else if(c=='A'){
      //increment ml
      if(temp==1){
        temp = 10;
        val2 = temp*4;
        clearLine(0,1);
        lcd.print(" drop(s)/min"); //recheck
      else{
        temp = temp + 5;
        val2 = temp*4;
        clearLine(0,1);
        lcd.print(" ml/hr"); //recheck
      else if (c=='B'){
        if(temp==10){
        temp = 1;
        val2 = 5;
        clearLine(0,1);
        else{
        temp = temp - 5;
        val2 = temp*4;
        clearLine(0,1);
      else{
        clearLine(0,1);
        lcd.setCursor(2,1);
        clearLine(0,1);
    }while(true);
    if(c=='C'){
      flagVal2 = false;
      val2 = 0;
    else{
      if(temp==1){
        val2 = 5;
        clearLine(0,1);
        flagVal2 = true;
        Serial.println("TEMP 1");
        flagVal2 = false;
        Serial.println("TEMP 2");
      else{
        val2 = temp;
        clearLine(0,1);
        flagVal2 = true;
        Serial.println("TEMP 3");
      //final checking
void pumpGo(){
    stepper.setSpeedRPM(60);
    stepper.setMicrostepping(3);
    stepper.rotate(360);
  lcd.setCursor(a,b);
  lcd.print("                ");
  lcd.setCursor(1,1);
bool airCheck(){
  if(analogRead(airPin)==0){
    return true;
  return false;
bool loadCheck(){
/*  if((scale.getGram(),1)<=.15*val1);{
    return true;
  return false; */
void pumpStop(){
    stepper.setMicrostepping(0);
    while(digitalRead(lockPump)){
    stepper.rotate(1);
void transmitXbee(int state){
  switch(state){
    case 1:
      xbeeCon.println("A,"); //sa java GUI nyo pag A nareceive display air occlusion
      //long a = (scale.getGram());
      //xbeeCon.print(a); // current level na natitira
      xbeeCon.print(",")
      xbeeCon.println("computed time...."); //time remaining  may calculations pa to
    case 2:
      xbeeCon.print("W,"); //sa java GUI nyo pag B nareceive display 15% chuchu
//      a = (scale.getGram());
     // xbeeCon.print(a); // current level na natitira
      xbeeCon.print(",")
      /*  comma-separated value
       *   example ng sent data
       *   W,800,3600
       *   sa java code mo na i interpret ang data
       *   tapos istore nyo sa .csv file para malog nyo
       *   1,X,kg,min
In the line
Pins are connect as follows.
Dir -- pin 4
Step -- pin 5
Ms1 -- pin 2
Ms2 -- pin 6
Slp -- pin 3
Gnd -- Gnd
This is the picture showing how a wider perspective with other modules.
I also have other things connected such as capacitive sensor and microswitch.
i had an I2C problem when i ran motors. i used an I2C expander to control some low current motors. it worked reliably w/o the motors connected.
i fixed the problem by adding pull-up resistors to the I2C clk and data lines
gcjr:
This where you should have presented us with a proper schematic so we could see how you connected everything.
A picture does not show the two resistors missing, a proper schematic would have.
Can I suggest you draw a schematic for your own reference.
Tom... :slight_smile:
gcjr:
Hello user gcjr!! I tried adding a 12k pull_up resistor to each keypad inputs and somehow reduced the random inputs slightly. I've studied the keypad library and saw some internal pullup definition within the code but I'm not sure how the code works to be honest.
TomGeorge:
Hi Tom! You quoted another person's comment so I'm not entirely sure hownto respond. Anyways, I still did the pullup thingy to no avail.
I studied the tb6600 diagram and learned that all signal pins of the driver are optically isolated from the arduino board. As stated before, we've used it previously but faced problems with the microstepping control since it required a manual switching of the dipswitch in the driver. In this connection, can anyone tell me how a stepper driver ic works? Does the ic generate some strong stray noise when powered? Does anyone have any experience in properly adding an optocoupler to a module before I waste my resource trying. Thank you
Have you got the Arduino gnd connected to the stepper power supply gnd.
Please a proper detailed circuit diagram.
Keep your stepper motor and powersupply wires away from the Arduino wires as much as possible.
If you disconnect the stepper, does the fault still happen
Thanks.. Tom.. :slight_smile:
TomGeorge:
  1. Yes. It's through the arduino GND -- Stepper Driver GND
  2. No.
Anyhow, we managed to solve the problem by using a linear 12v power supply, the psu we were using before were generic 12v switching power supplies. We were on the verge of ordering 6n137 optocouplers to isolate the circuit. To those who will someday find this thread, make sure to isolate the driver from the arduino (with optocoupler ckt/breakout boards), suppress ground loop interference by properly adding the required components (search power supply decoupling) and lastly try powering your driver with a battery cell/linear psu.
Thanks
