Interference on I2C bus
Hello erveryone,
I have a problem with my project. Im using a Lilygo TTGO Lora32 V1.6.1 board with intergrated OLED and LoRa chip. i've added an BME280 sensor to the project.
The problem that im running into is that when i add the BME280 sensor on the I2C bus that de OLED screen only shows static. I can't reset it. Only when is remove the power from the board.
I will add the code below. Note that some functions are commented out. This are future functions.
Lilygo TTGO LoRa32 V1.6.1 With BME280.
Future:
- Ultrasonic Sensor
- MCP23017 I2C IO Expander
//Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//Libraries for BME280
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 23
#define DIO0 26
//433E6 for Asia
//866E6 for Europe
//915E6 for North America
#define BAND 433E6
//OLED pins
#define OLED_SDA 21
#define OLED_SCL 22
#define OLED_RST 13
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
//BME280 definition
#define SDA 21
#define SCL 22
TwoWire I2Cone = TwoWire(1);
Adafruit_BME280 bme;
//packet counter
int readingID = 0;
int counter = 0;
String LoRaMessage = "";
float temperature = 0;
float humidity = 0;
float pressure = 0;
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
//int ultraSonicTrig = 4;
//int ultraSonicEcho = 36;
//long duration, cm;
//Initialize OLED display
void startOLED(){
  //reset OLED display via software
  pinMode(OLED_RST, OUTPUT);
  digitalWrite(OLED_RST, LOW);
  delay(20);
  digitalWrite(OLED_RST, HIGH);
  //initialize OLED
  Wire.begin(OLED_SDA, OLED_SCL);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.setCursor(0,0);
  display.print("LORA SENDER");
//Initialize LoRa module
void startLoRA(){
  //SPI LoRa pins
  SPI.begin(SCK, MISO, MOSI, SS);
  //setup LoRa transceiver module
  LoRa.setPins(SS, RST, DIO0);
  while (!LoRa.begin(BAND) && counter < 10) {
    Serial.print(".");
    counter++;
  if (counter == 10) {
    // Increment readingID on every new reading
    readingID++;
    Serial.println("Starting LoRa failed!");
    // Change sync word (0xF3) to match the receiver
  // The sync word assures you don't get LoRa messages from other LoRa transceivers
  // ranges from 0-0xFF
  LoRa.setSyncWord(0xFF);
  Serial.println("LoRa Initialization OK!");
  display.setCursor(0,10);
  display.print("LoRa Initializing OK!");
  display.display();
  delay(2000);
void startBME(){
  I2Cone.begin(SDA, SCL, 100000);
  bool status1 = bme.begin(0x76, &I2Cone);
  if (!status1) {
    Serial.println("Could not find a valid BME280_1 sensor, check wiring!");
    while (1);
void getReadings(){
  temperature = bme.readTemperature();
  humidity = bme.readHumidity();
  pressure = bme.readPressure() / 100.0F;
  // The sensor is triggered by a HIGH pulse of 20 or more microseconds.
      // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  digitalWrite(ultraSonicTrig, LOW);
  delayMicroseconds(5);
  digitalWrite(ultraSonicTrig, HIGH);
  delayMicroseconds(20);
  // Read the signal from the sensor: a HIGH pulse whose
  // duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(ultraSonicEcho, INPUT);
  duration = pulseIn(ultraSonicEcho, HIGH);
  // Convert the time into a distance
  cm = (duration/2) / 29.1;     // Divide by 29.1 or multiply by 0.0343
void sendReadings() {
  LoRaMessage = String(readingID) + "/" + String(temperature) + "&" + String(humidity) + "#" + String(pressure);
  //Send LoRa packet to receiver
  LoRa.beginPacket();
  LoRa.print(LoRaMessage);
  LoRa.endPacket();
  display.print("LoRa packet sent!");
  display.setCursor(0,20);
  display.print("Temperature:");
  display.setCursor(72,20);
  display.print(temperature);
  display.setCursor(0,30);
  display.print("Humidity:");
  display.setCursor(54,30);
  display.print(humidity);
  display.setCursor(0,40);
  display.print("Pressure:");
  display.setCursor(54,40);
  display.print(pressure);
  display.setCursor(0,50);
  display.print("Reading ID:");
  display.setCursor(66,50);
  display.print(readingID);
  display.display();
  Serial.print("Sending packet: ");
  Serial.println(readingID);
  readingID++;
void printReadings(){
  Serial.print("T: ");
  Serial.print(temperature);
  Serial.print(", H: ");
  Serial.print(humidity);
  Serial.print(", P: ");
  Serial.print(pressure);
  //Serial.print(", D: ");
  //Serial.print(cm);
  //Serial.print("cm");
  //initialize Serial Monitor
  Serial.begin(115200);;
  startOLED();
  startBME();
  startLoRA();
  //pinMode(ultraSonicTrig, OUTPUT);
  //pinMode(ultraSonicEcho, INPUT);
  getReadings();
  sendReadings();
  printReadings();
  delay(10000);
Note that the I2C pins are defined twice. This is because the 2 libraries both call them different.
Thankyou for your help!
Rick
I suspect that is your problem. You might need a board with two I2C bus's
It is important to use the most simple and most straightforward code that everyone else uses. Can you use the I2C bus in the most common way ?
Please remove this:
That was maybe needed for a short time many years ago.
Just use Wire and Wire1.
Use the default for Wire.begin(), don't use the parameters for the pin numbers:
Wire.begin();
Call that in setup().
Remove this:
//BME280 definition
#define SDA 21
#define SCL 22
They are already defined.
Remove this as well:
#define OLED_SDA 21
#define OLED_SCL 22
wow this is it. thanks for your help!
i2c requires one pull-up resistor oneach signal. do you have them?
