Interference when using multiple PWM pins
I am using PWM pins, h-bridge driver and the analogueWrite() function to control the speed and direction of a DC motor using an accelerometer data I am transmitting wirelessly. The x-axis of the accelerometer will cause the DC motor to rotate when tilted forward or backwards.
I then wanted to use the y-axis of the accelerometer to control a servo motor when tilted right or left.
I am using PWM pins to send signals to the h-bridge for the dc motor but when I used another PWM for the servo, the servo rotates when I tilt the accelerometer forward. Even when I take out the code for the servo to rotate, it still moves and twitches as if the signals from the other PWM pins are being sent to the pin attached to the servo
Any ideas what could be the problem?
I have attached my code and circuit.
Thanks,
Rui
//Code to control dc motor and servo using ADXL-335
#include <XBee.h>
#include <SoftwareSerial.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
const int motor1Pin = 3;    // H-bridge leg 1 (pin 2, 1A)
const int motor2Pin = 5;    // H-bridge leg 2 (pin 7, 2A)
const int enablePin = 6;    // H-bridge enable pin
int x_axis = 0;
int y_axis = 0;
int z_axis = 0;
int axis[3];
This example is for Series 1 XBee Radios only
Receives I/O samples from a remote radio with 16-bit addressing.
The remote radio must have IR > 0, at least one digital or analog input enabled
and DL set to the 16-bit address of the receiving XBee (the one connected to the Arduino).
This example uses the SoftSerial library to view the XBee communication.  I am using a
Modern Device USB BUB board (http://moderndevice.com/connect) and viewing the output
with the Arduino Serial Monitor.
XBee xbee = XBee();
Rx16IoSampleResponse ioSample = Rx16IoSampleResponse();
  xbee.setSerial(Serial);
  // set all the other pins you're using as outputs:
  pinMode(motor1Pin, OUTPUT);
  pinMode(motor2Pin, OUTPUT);
  pinMode(enablePin, OUTPUT);
  // set enablePin high so that motor can turn on:
  digitalWrite(enablePin, HIGH);
  myservo.attach(10);  // attaches the servo on pin 5 to the servo object
  //attempt to read a packet
  xbee.readPacket();
  if (xbee.getResponse().isAvailable()) {
    // got something
    if (xbee.getResponse().getApiId() == RX_16_IO_RESPONSE) {
      xbee.getResponse().getRx16IoSampleResponse(ioSample);
      Serial.println("Received I/O Sample from Xbee address: ");
      Serial.print(ioSample.getRemoteAddress16(), HEX);
      Serial.print("Sample size is ");
      Serial.println(ioSample.getSampleSize(), DEC);
      if (ioSample.containsAnalog()) {
        Serial.println("Sample contains analog data");
      if (ioSample.containsDigital()) {
        Serial.println("Sample contains digtal data");
      for (int k = 0; k < ioSample.getSampleSize(); k++) {
        Serial.print("Sample ");
        Serial.print(k + 1, DEC);
        Serial.println(":");
        for (int i = 0; i <= 3; i++) {
          if (ioSample.isAnalogEnabled(i)) {
            Serial.print("Analog (AI");
            Serial.print(i, DEC);
            Serial.print(") is ");
            Serial.println(ioSample.getAnalog(i, k));
            axis[i] = ioSample.getAnalog(i, k);
        x_axis = constrain(axis[2], 400, 595);    //Constrain the x-axis values we receive to a range
        y_axis = constrain(axis[1], 405, 595);    //Constrain the y-axis values we receive to a range
        if(x_axis > 490 && x_axis < 510) // If the accelerometer is flat on x-axis
        analogWrite(enablePin, HIGH);    // This allows speed control of the motor.
        //Stop motor (brake)
        digitalWrite(motor1Pin, LOW);    // set leg 1 of the H-bridge low
        digitalWrite(motor2Pin, LOW);   // set leg 2 of the H-bridge low
        Serial.println("Motor stopped"); //output message to serial monitor
        if(x_axis < 490)                //If tilted forward, rotate dc  motor clockwise
        x_axis = map(x_axis, 400, 489, 255, 0);   //Map the x-axis values values to the PWM output range
        Serial.println("Rotate motor forwards");
        //Rotate clockwise
        digitalWrite(motor2Pin, HIGH);  // set leg 2 of the H-bridge high
        analogWrite(enablePin, x_axis); // This allows speed control of the motor.
        else if(x_axis > 510)  //if the accelerometer is being tilted backwards.
        x_axis = map(x_axis, 511, 600, 0, 255); //map values to 0-255
        //Rotate anti-clockwise
        digitalWrite(motor1Pin, HIGH);   // set leg 1 of the H-bridge high
        Serial.println("Rotate motor backwards");
        //Contro steering using the y_axis values
        if(y_axis > 480 && y_axis < 510) // If the accelerometer is flat on y-axis
         myservo.write(90);                  // sets the servo position according to the scaled value
         Serial.println("Steering centered"); //output message to serial monitor
        if(y_axis < 480)  // if accelerometer is tilted left
         y_axis = map(y_axis, 400, 479, 0, 90);     // scale it to use it with the servo (value between 0 and 90)
         myservo.write(y_axis);                  // sets the servo position according to the scaled value
         delay(15);
         Serial.println("Turn servo left");
        else if(y_axis > 510)  //if the accelerometer is being tilted right.
         y_axis = map(y_axis, 511, 600, 90, 180);     // scale it to use it with the servo (value between 90 and 180)
         delay(15);
         Serial.println("Turn servo right");
Arduino_Rx_dc.fzz (7.86 KB)
