im trying to intergrate
`#include "Mouse.h"
#include "Keyboard.h"
// set pin numbers for switch, joystick axes, and LED:
const int switchPin = 2; // switch to turn on and off mouse control
const int mouseButton = 3; // input pin for the mouse pushButton
const int xAxis = A0; // joystick X axis
const int yAxis = A1; // joystick Y axis
const int ledPin = 5; // Mouse control LED
// parameters for reading the joystick:
int range = 12; // output range of X or Y movement
int responseDelay = 5; // response delay of the mouse, in ms
int threshold = range / 4; // resting threshold
int center = range / 2; // resting position value
bool mouseIsActive = false; // whether or not to control the mouse
int lastSwitchState = LOW; // previous switch state
pinMode(switchPin, INPUT); // the switch pin
pinMode(ledPin, OUTPUT); // the LED pin
// take control of the mouse:
Mouse.begin();
// read the switch:
int switchState = digitalRead(switchPin);
// if it's changed and it's high, toggle the mouse state:
if (switchState != lastSwitchState) {
if (switchState == HIGH) {
mouseIsActive = !mouseIsActive;
// turn on LED to indicate mouse state:
digitalWrite(ledPin, mouseIsActive);
// save switch state for next comparison:
lastSwitchState = switchState;
// read and scale the two axes:
int xReading = readAxis(A0);
int yReading = readAxis(A1);
// if the mouse control state is active, move the mouse:
if (mouseIsActive) {
Mouse.move(xReading, yReading, 0);
if(xReading != yReading){
Keyboard.print("i");
// read the mouse button and click or not click:
// if the mouse button is pressed:
if (digitalRead(mouseButton) == HIGH) {
// if the mouse is not pressed, press it:
if (!Mouse.isPressed(MOUSE_LEFT)) {
Mouse.press(MOUSE_LEFT);
// else the mouse button is not pressed:
else {
// if the mouse is pressed, release it:
if (Mouse.isPressed(MOUSE_LEFT)) {
Mouse.release(MOUSE_LEFT);
delay(responseDelay);
reads an axis (0 or 1 for x or y) and scales the analog input range to a range
from 0 to
int readAxis(int thisAxis) {
// read the analog input:
int reading = analogRead(thisAxis);
// map the reading from the analog input range to the output range:
reading = map(reading, 0, 1023, 0, range);
// if the output reading is outside from the rest position threshold, use it:
int distance = reading - center;
if (abs(distance) < threshold) {
distance = 0;
// return the distance for this axis:
return distance;
}with my code
#include <Keyboard.h>
#include <KeyboardLayout.h>
#include <Mouse.h>
const byte scrollPin = A5;
int currentPotValue;
int scrollBy;
int oldPotValue;
const int Xpin = A0;
const int Ypin = A1;
String potValueString = "Current Pot Value: ";
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
Serial.begin(19200);
oldPotValue = analogRead(scrollPin);
void loop(){
if(digitalRead(1) == LOW)
Keyboard.print("1");
if(digitalRead(2) == LOW)
Keyboard.print("2");
if(digitalRead(3) == LOW)
Keyboard.print("3");
if(digitalRead(4) == LOW)
Keyboard.print("4");
if(digitalRead(5) == LOW)
Keyboard.print("z");
if(digitalRead(6) == LOW)
Keyboard.print("x");
if(digitalRead(7) == LOW)
Keyboard.print("c");
if(digitalRead(8) == LOW)
Keyboard.print(" ");
int currentPotValue = analogRead(scrollPin);
int scrollBy = currentPotValue - oldPotValue;
if (abs(scrollBy) > 5) {
scrollBy *= 0.1;
Mouse.move(0,0,scrollBy);
oldPotValue = currentPotValue;
Serial.print(potValueString);
Serial.println(currentPotValue);
Serial.print("scrollBy Value: ");
Serial.println(scrollBy);
delay(10);
i cant figure out how to pls help
