Intermittent error while burning bootloader to Atmega328P
Hi guys,
I seek your expert help to find the root cause to a mysterious problem I keep having recently.
I have a custom Arduino board based on the Atmega328 controller. I burn the bootloader myself to these boards (using the Optiboot) and already made a few hundreds of them.
But recently about 10% of my boards cannot be bootloaded, I get the error message:
avrdude: Device signature = 0x1e00f0
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
Error while burning bootloader.
I used to mount the TQFP package version of the controller earlier, and with those guys I did not have this problem at all. Subsequently I changed to QFN due to its size and since I keep having this issue. No idea if it has to do with the new package though, as of course the board layout itself also changed.
I only have one Nano-based breadboard I use to burn the bootloader and did it several hundred times. Therefore that cannot be the issue. I tried burning the bootloader of other types like Nano, Micro, MiniCore etc., to no avail (not that I expected). All boards I can bootload can be bootloaded reproducably. Same is true unfortunately for those I cannot. :confused:
I checked the affected boards, they are recognized, therefore the FTDI chip is OK (I know it has nothing to do with the bootloader). I checked voltages, all OK. Caps, especially the one between reset/DTR is OK. Current consumption of affected boards are inside the spec, no obvious sign of short/board damage, except maybe that the Rx/Tx LEDs sometimes flash or stay lit when connecting the ICSP header.
I had the Atmega328P swapped on all of the affected boards, no change. Therefore it cannot be the chip itself, I anyway only buy from DigiKey and 10% is way more than the 100ppm I expect from chips for the consumer electronics ...
This is the full verbose log I get for one of such a board.
I noticed however that the differing signature complained about by the IDE is not always the same even for the same device...
What could be the problem? Is there any way to detect if the controllers are still OK? How to use that -F override function? Haven't found anything on that...
C:\Users\MunkaGep\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.0.1-arduino2/bin/avrdude -CC:\Users\MunkaGep\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.0.1-arduino2/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Mar 19 2015 at 14:43:01
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Users\MunkaGep\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.0.1-arduino2/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.06s
