I'm having some trouble "resetting" the Wiper OFF interval timer when the latching switch input is removed, returning back to the start of the loop awaiting another input as such.
The Wiper OFF interval timer continues to run for the 8 seconds before it allows another wiper relay output. So if the switch input is received during this 8 second OFF interval then the Wiper Relay won't turn ON again until after it has expired. Would give the impression that the wipers weren't working within this period.
I've been looking at various methods of doing this throughout the past few weeks but with no joy. I've tried button state flags which I thought would have been the way around this, but may not have had them setup correctly.
See below code as it stands now without any Button State flags etc. I've only recently got to grips with Arduino again after a few years away from it, so there may be other ways around doing this.
Thanks in advance for any help
//OUTPUTS:************************
int WiperRelay = 10; //Windscreen Wiper Output
//INPUTS*************************
int WiperInt = 4;
//Constants***************************
const int wipOnTime = 1500; //Enough time to pass the Wiper Stop point
const int wipOffTime = 8000;
//Variables*******************************
long WiperOnMillis = 0; // Time stamp for when the wipers relay last went to 1(HIGH). Initially set to 0(LOW)
int interval = wipOnTime;
int WiperState = LOW;
int WiperIntSwitchVal = 0;
int previousWiperIntSwitchVal = 0;
long WiperSwitchMillis = 0; // Time stamp for when the switch last went to 1(HIGH). Initially set to 0(LOW)
pinMode(WiperInt, INPUT_PULLUP);
pinMode(WiperRelay, OUTPUT);
unsigned long currentMillis = millis(); //saves the time at the start of the loop
if (WiperState == LOW) {
WiperIntSwitchVal = digitalRead(WiperInt); //Reads the wiper switch and writes to a variable
WiperIntSwitchVal = LOW;
if ((WiperIntSwitchVal == LOW) && (previousWiperIntSwitchVal == HIGH)) //compares current switch status to previous
previousWiperIntSwitchVal = WiperIntSwitchVal; //sets the current status as the old status in preparation for the next check
WiperSwitchMillis = currentMillis; //sets a time stamp at the current time
if ((WiperIntSwitchVal == LOW) && (currentMillis - WiperOnMillis >= interval))
WiperOnMillis = currentMillis; //saves current time
interval = wipOffTime;
WiperState = !(WiperState);
digitalWrite(WiperRelay, WiperState); //sets the output to the windscreen wipers with the state of the variable
