internal 1.1v reference not working?
Hi!
i am trying to read a battery voltage, made voltage divider and the output voltage of that is around 1.00V at the moment.
using analogread with the default reference gives me a value of around 218 (fits) but using the internal 1.1v reference gets me a value of 212. Whats wrong there?
void loop(void)
analogReference(INTERNAL);
int adc = analogRead(A0);
delay(10);
its in the loop and the values stay around the same.
any ideas?
Thanks!
What model of Arduino are you using? Complete code might help too.
And .... I would put the and “analogreference” bit in setup
  • when you change the reference the first few values can be in error - it looks like you are setting the reference every time you loop, not sure but that might be the problem ?
Google “ Arduino internal reference”
You’ve not listed all your code , so there may be other mistakes .
