I've got a program that is using the internal 1.1v reference to increase the read resolution of an LM35 temperature sensor output using analogReference(INTERNAL);
However, is there a way for me to set analogReference to 1.1v on specific analog pins, and 5v on other pins?
The other option is to use an external ADC. Then you can have 2 voltage references - the one for the internal ADC, and a different one for the external ADC.
I am working on an ADC shield at the moment: http://hacking.majenko.co.uk/node/58 and in my testing of it I use the internal ADC of the Arduino to monitor the Vref of the external ADC.
I feared that would be the problem.... the dreaded delay.
It is not necessary to delay(). Simply discard the first reading after switching reference voltages.
Simply discard the reading? Sorry?
What I meant, was to be able to simultaneously read the input from an LM35, whilst reading other 0 - 5v sensors - in addition to running numerous other I/Os. A delay of any sort is a delay is it not?
jtw11:
You can't simultaneously read more than one analog input anyway. There is only one ADC. The pins go into a MUX, which sits in front of the lone ADC.
