Internal Clock Function
To start, I will give you a bit of info on my project. I am doing an associative learning experiment with fish. This will require a training period of a couple of weeks, and I would like to fully automate the process so that I will only have to spend a minute or two a day refilling the food. I am wondering if the Arduino has an internal clock function?
I will be using a servo motor to rotate a plastic tube containing a pre-rationed amount of food, and I would like this to happen every 2 hours for 6 hours from 10 AM to 4 PM (first at 10 am, second at 12 pm, third at 2 pm, last at 4 pm).
I was wondering if there was anyway for the arduino board to tell the time? For example, if I plug the Arduino board in at 9:50 AM, is there a way for it to know that it is 10:00 AM and to rotate the servo? Or do I have to tell the board to wait ten minutes in the code? And then is there anyway for me to tell it to rotate the motor again at 12:00 PM?
My reasoning for wanting to do this, is, should the board lose power, if I was to tell the board to wait a specific amount of time instead of having it reference the actual time, then the whole time schedule would get messed up. Is what I am describing possible? Please let me know if you are confused or if I am not being clear. I am very new to programming and could use as much help as possible.
I think I will try to use the default Arduino Sweep sketch and modify that. Is there an easier way to do it?
Thanks for reading
Sorry, I forgot to mention I will be using an Arduino Uno Make Special Edition
The code I was thinking of using was the stock servo sweep sketch, as it works for the mechanism of feeding I would like to use
The code is this (note, I have not done anything to it, except verified that my motor will rotate correctly)
#include <Servo.h>
Servo myservo;
int pos = 0;
  myservo.attach(9);
  for(pos = 0; pos < 180; pos += 1)
    myservo.write(pos);
    delay(15);
  for(pos = 180; pos>=1; pos-=1)
    myservo.write(pos);
    delay(15);
Given your requirements you should have a look at a Real Time Clock or RTC.
The DS1307 is a reasonable one, far more accurate is the DS3231.
For both libraries and examples are available.
robtillaart:
Thank you for the reply! But why exactly would this be the best option? Is it because this would be a definite way incase the board powers down, or would it simply not be practical to try to do it without an RTC?
it sort of has a time function. what it has is "millis().
this starts counting once ever 1/1000 second fronm the moment you plug in the arduino.
using this you can tell it when to open and close the feeding window/door/whatever.
so something like this may work.
/* written by Justin Holman aka Remy5405 of Diminsional Designs
on 10/26/2014 to act as a referance point to help a fellow coder understand the logic layout of a automated fish feeding program
feel free to use as much or little of this code as you want. just please keep this text in it
#include <Servo.h>
Servo foodMotor; // using a servo to rotate the food tube door. called it foodMotor
unsigned long timeSinceFeed; // make a int for the time since last feed
const long timeToFeed = 60*60*2*1000; // a value to set the 2 hrs to leave door open. 60sec times 60min times 2 hrs times 1000 for the mills
const int timeBetweenFeeding = 60*60*4*1000; // making that 6 hr delay
long timeOfFeed; // makes a blank int to assign the current feeding millis to
void setup(){
foodMotor.attach(1); // hooked your servo to pin one of arduino
foodMotor.write(0); // set the servo starting point, taking it this is the closed postion
delay(100); // lets the servo get to 0 before anymore code runs
timeSinceFeed = millis(); // starting the time tell next feeding timer. this writes the current mills time to the timeSinceFeed
void loop(){
  if (timeSinceFeed >= timeBetweenFeeding + timeToFeed){ // checks to see if its been 6 hrs since last feed
    foodMotor.write(180); // moves the servo to open the feeder
    timeSinceFeed = millis(); //resets timer between feedings
    timeOfFeed = millis(); //starts the time of this current feeding cycle
  if (timeOfFeed >= timeToFeed){ // checks to see if the 2 hrs to stay open have passed
    foodMotor.write(0); // if so it closes the servo controlled feeding door/window/whatever
    timeOfFeed = millis(); //resets the current time stamp so if loop wont stall
Hope this Helps
If you want the system to remember the time during power off, you need a battery backed real time clock, they are available, we sell them if you are in the UK.
They connect over I2C and then you use a library to talk to it. They really are quite useful.
On it's own an Arduino can count milliseconds but can't keep counting whilst it is off.
