I've researched a bit, and I've ran into a couple of examples of how buttons are used as interrupts. However, the design I'm trying to implement uses analog sensors. Right now, what I want to do is to have my analog sensors flag a boolean to tell the interrupt to execute, not a button. How would I do so?
This is what I have thought up based on what I researched:
Only in a most awkward and unnecessary manner. Interrupts are cause by external events, like serial data arriving, or by things that happen very frequently, and need to not be missed, like encoders rotating.
If a switch is connected, it should be polled in loop().
Analog devices do not trigger interrupts, because the time taken to read an analog sensor is so long, in terms of how many times loop() could loop, that polling is fast enough.
Let's get back to the real world. What is your application? Why do you need to know if an analog input changes? Is this something to do with watering plants? If so you hardly need to turn the sprinklers on with microsecond precision.
