internal pullup and interrupts
hello,
I am trying to use interrupt 0 (pin2 on an arduino uno r3 board) to measure rpm for an computer fan with an 10k resistor connected between arduino 5v and digital pin 2 I get somehow accurate readings without the 10k resistor and with internal pull-up activated I get readings all over the place, even lower values for increasing rpms
I have tried both:
pinMode(2, INPUT_PULLUP); and
digitalWrite(2, HIGH);
without any luck
can internal pull-up resistors be used in conjunction with interrupts ? am I doing something wrong in the way I activate them ?
thanks, razvan radu
The problem is likely that the internal pull-ups are weak - 3 to 5 times weaker than 10k. Try an external 4k7 and see if its even better than the 10k (should reject noise much better).
