Ok so I doubt this will be a hard problem to fix. I really need to set up multiple html buttons that each controls a separate pin. Like a button to control pin 4 and a different one for pin 5 and so on.
As you can see my code is below. I already have the pins enabled and everything is wired correctly I just need to make a separate button to control each pin.
( code tags added by moderator)
#include <SPI.h>
#include <Client.h>
#include <Ethernet.h>
#include <Server.h>
#include <Udp.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 0, 110 }; // ip in lan
byte gateway[] = { 192, 168, 0, 1 };
// internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
int pin = 4; // LED pin
int pin2 = 5;
int pin3 = 2;
int pin4 = 3;
int pin5 = 6;
int pin6 = 7;
int pin7 = 8;
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
void setup(){
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
//Set pin 2-8 to output
pinMode(pin, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
pinMode(pin5, OUTPUT);
pinMode(pin6, OUTPUT);
pinMode(pin7, OUTPUT);
//enable serial datada print
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100)
//store characters to string
readString += c; //replaces readString.append(c);
//output chars to serial port
Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
//dirty skip of "GET /favicon.ico HTTP/1.1"
if (readString.indexOf("?") <0)
//skip everything
//lets check if LED should be lighted
if(readString.indexOf("L=1") >0)//replaces if(readString.contains("L=1"))
//led has to be turned ON
digitalWrite(pin, HIGH); // set the LED on
digitalWrite(pin2, HIGH);
digitalWrite(pin3, HIGH);
digitalWrite(pin4, HIGH);
digitalWrite(pin5, HIGH);
digitalWrite(pin6, HIGH);
digitalWrite(pin7, HIGH);
LEDON = true;
}else{
//led has to be turned OFF
digitalWrite(pin, LOW); // set the LED OFF
digitalWrite(pin2, LOW);
digitalWrite(pin3, LOW);
digitalWrite(pin4, LOW);
digitalWrite(pin5, LOW);
digitalWrite(pin6, LOW);
digitalWrite(pin7, LOW);
LEDON = false;
// now output HTML data starting with standart header
client.println("Content-Type: text/html");
client.println();
//set background to yellow
client.print("<body style=background-color:yellow>");
//send first heading
client.println("<font color='red'><h1>Power Control Prototype</font></h1>");
client.println("<hr />");
//controlling led via checkbox
client.println("<h1>LED control</h1>"); //address will look like http://192.168.0.110/?L=1 when submited
if (LEDON)
client.println("<form method=get name=LED><input type=checkbox name=L value=0>LED
<input type=submit value=submit></form>");
client.println("<form method=get name=LED><input type=checkbox name=L value=1>LED
client.println("
//printing LED status
client.print("<font size='5'>LED status: ");
if (LEDON)
client.println("<font color='green' size='5'>ON");
client.println("<font color='grey' size='5'>OFF");
client.println("</body></html>");
//clearing string for next read
readString="";
//stopping client
client.stop();
