Internet.h
Bonjour, j’ai besoin de cette librairie dans une projet Mysql.
Je n’arrive pas à compiler, il me demande toujours un autre fichier .h.
Par exemple types.h etc…
Je suis un peu perdu !
Merci d’avance,
bonjour,
si tu mettais le code entre balise code </> ainsi que l’erreur en forme texte, ca ne serait pas plus simple pour aider?
Bonjour,
Désolé, voici le code: (dessous … le message)
Merci d’avance,
  MySQL Connector/Arduino Example : basic select
  This example demonstrates how to issue a SELECT query with no parameters
  and use the data returned. For this, we use the Cursor class to execute
  the query and get the results.
  It demonstrates who methods for running queries. The first allows you to
  allocate memory for the cursor and later reclaim it, the second shows how
  to use a single instance of the cursor use throughout a sketch.
  NOTICE: You must download and install the World sample database to run
          this sketch unaltered. See http://dev.mysql.com/doc/index-other.html.
  CAUTION: Don't mix and match the examples. Use one or the other in your
           own sketch -- you'll get compilation errors at the least.
  INSTRUCTIONS FOR USE
  1) Change the address of the server to the IP address of the MySQL server
  2) Change the user and password to a valid MySQL user and password
  3) Connect a USB cable to your Arduino
  4) Select the correct board and port
  5) Compile and upload the sketch to your Arduino
  6) Once uploaded, open Serial Monitor (use 115200 speed) and observe
  Note: The MAC address can be anything so long as it is unique on your network.
  Created by: Dr. Charles A. Bell
#include <Ethernet.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server_addr(10,0,1,35);  // IP of the MySQL *server* here
char user[] = "root";              // MySQL user login username
char password[] = "secret";        // MySQL user login password
// Sample query
char query[] = "SELECT population FROM world.city WHERE name = 'New York'";
EthernetClient client;
MySQL_Connection conn((Client *)&client);
// Create an instance of the cursor passing in the connection
MySQL_Cursor cur = MySQL_Cursor(&conn);
  while (!Serial); // wait for serial port to connect
  Ethernet.begin(mac_addr);
  Serial.println("Connecting...");
  if (conn.connect(server_addr, 3306, user, password)) {
    Serial.println("Connection failed.");
  row_values *row = NULL;
  long head_count = 0;
  Serial.println("1) Demonstrating using a cursor dynamically allocated.");
  // Initiate the query class instance
  MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
  // Execute the query
  cur_mem->execute(query);
  // Fetch the columns (required) but we don't use them.
  column_names *columns = cur_mem->get_columns();
  // Read the row (we are only expecting the one)
  do {
    row = cur_mem->get_next_row();
    if (row != NULL) {
      head_count = atol(row->values[0]);
  } while (row != NULL);
  // Deleting the cursor also frees up memory used
  delete cur_mem;
  // Show the result
  Serial.print("  NYC pop = ");
  Serial.println(head_count);
  Serial.println("2) Demonstrating using a local, global cursor.");
  cur.execute(query);
  cur.get_columns();
  do {
    row = cur.get_next_row();
    if (row != NULL) {
  // Now we close the cursor to free any memory
  cur.close();
  // Show the result but this time do some math on it
  Serial.print("  NYC pop increased by 12 = ");
  Serial.println(head_count+12);
le message :
ATTENTION : La catégorie '' dans la bibliothèque UIPEthernet n'est pas valide. Définition sur : 'Uncategorized'
In file included from C:\Users\leuleu\Documents\Arduino\libraries\Ethernet\src/variant.h:36:0,
                 from C:\Users\leuleu\Documents\Arduino\libraries\Ethernet\src/SPI.h:14,
                 from C:\Users\leuleu\Documents\Arduino\libraries\Ethernet\src\utility/w5100.h:13,
                 from C:\Users\leuleu\Documents\Arduino\libraries\Ethernet\src\Dhcp.cpp:4:
C:\Users\leuleu\Documents\Arduino\libraries\Ethernet\src/Arduino.h:84:25: fatal error: USB/USBDesc.h: No such file or directory
 #include "USB/USBDesc.h"
compilation terminated.
Plusieurs bibliothèque trouvées pour "Ethernet.h"
Utilisé : C:\Users\leuleu\Documents\Arduino\libraries\Ethernet
Non utilisé : C:\Program Files (x86)\Arduino\libraries\Ethernet
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
