interpreting HTML in combination with SD
Hey guys,
I have an arduino uno and an ethernetshield. I am running a little Webserver that gives me the value of an analog sensor. So far so good, once I include SD.h the html sent to the client is corrupt and the output in the browser is not as expected.
Attached are 2 screenshots. One showing how I expect it to look like and the other shows how it looks like once I include SD.h
the code looks as follows:
THANKS A LOT IN ADVANCE
#include <SPI.h>
#include <Ethernet.h>
//#include <SD.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,178,179);
const int chipSelect = 4;
int outputPin = 6;
EthernetServer server(80);
Serial.begin(57600);
pinMode(10, OUTPUT);
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
pinMode(outputPin, OUTPUT);
int sensorValue = analogRead(A0);
float humidityPerCent = 100-(sensorValue /10.23);
if (client) {
Serial.println("new client");
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
if (c == '\n' && currentLineIsBlank) {
client.println( "");
client.println( "The Garduino");
client.println( "body, input, select, textarea");
client.println( "{color: #888;font: 16pt "Source Sans Pro", sans-serif; width: 75%; margin:0 auto;}");
client.println( ".gradient { height: 50px; margin: 0 0 50px 0;");
//*** THE GRADIENTS SHOULD BE DEPENDING ON THE BOUNDARY VALUES***
client.println( "background: -webkit-linear-gradient(left, #69482D 10%, #1B701B 45%, #1B701B 55%, #1E315E 90%);"); /* For Safari 5.1 to 6.0 /
client.println( "background: -o-linear-gradient(right, #69482D 10%, #1B701B 45%, #1B701B 55%, #1E315E 90%);"); /
For Opera 11.1 to 12.0 /
client.println( "background: -moz-linear-gradient(right, #69482D 10%, #1B701B 45%, #1B701B 55%, #1E315E 90%);"); /
For Firefox 3.6 to 15 /
client.println( "background: linear-gradient(to right, #69482D 10%,#1B701B 45%, #1B701B 55%, #1E315E 90%);}"); /
Standard syntax (must be last) /
client.println( ".box{float: left !important; height: 50px;}");
** THE BOXES WIDTHS SHOULD BE DEPENDING ON THE BOUNDARY VALUES***
client.println( ".box.dry{width: 40%;}");
client.println( ".box.good{width: 20%; border-left:2px solid #888; border-right:2px solid #888;}");
client.println( ".box.humid{width: 37%}");
client.println( ".level{text-align: right; height: 50px; border-right: 2.5px solid #444;}");
client.println( ".level.bad{border-right:2.5px solid #c33;}");
client.println( "
The Garduino measures the humidity
of the ficus benjaminus
//*** LOOP ALL POTENTIAL SENSORS ***
client.println( "top soil sensor");
client.println( "<div class ="gradient">");
client.println( "<div class="box dry"> <div class="box good"> <div class="box humid"> ");
client.print( "<div class="level bad" style="width:");
client.print( humidityPerCent);
client.print( "%;">");
client.print( "%");
//*** END LOOP ***
client.println("");
if (c == '\n') {
else if (c != '\r') {
currentLineIsBlank = false;
delay(1);
client.stop();
Serial.println("client disconnected");
You are not sending a response header.
// add this line
        client.println(F("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n"));
        client.println( "<!DOCTYPE HTML>");
        client.println( "<html>");
        client.println( "<head>");
edit: Plus what PaulS mentions below. Use the F() function as I did with the header.
I'd hazard a guess that there is a 99.99+% probability that you are using more SRAM than your Arduino has.
You can keep string literals out of SRAM by using the F() macro:
client.println(F( "" ));
Below is an example of a web page bundled in a single F() macro. bundling like this can be broken in to parts if variables need to be printed in the page.
//example of web page bundled in single F() macro
//get submit box code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html or use a '
//address will look like http://192.168.1.102:84 when submitted
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
 pinMode(5, OUTPUT); //pin selected to control
 pinMode(6, OUTPUT); //pin selected to control
 pinMode(7, OUTPUT); //pin selected to control
 pinMode(8, OUTPUT); //pin selected to control
 //start Ethernet
 Ethernet.begin(mac, ip, gateway, gateway, subnet);
 server.begin();
 //enable serial data print
 Serial.println(F("server text box test1")); // so I can keep track of what is loaded
void loop(){
 // Create a client connection
 if (client) {
       //read char by char HTTP request
       if (readString.length() < 100) {
         //store characters to string
         readString += c;
         //Serial.print(c);
       //if HTTP request has ended
       if (c == '\n') {
         Serial.println(readString); //see what was captured
         //now output HTML data header
client.print(F(  //start F() macro
"HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n"
"<HTML>"
"<HEAD>"
"<meta name='apple-mobile-web-app-capable' content='yes' />"
"<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />"
"<TITLE>JAVA Page</TITLE>"
"</HEAD>"
"<BODY>"
"<H1>JAVA</H1>"
"<hr />"
"<FORM ACTION='/' method=get >"
"Enter Code: <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'>
"<input type=submit value='5 ON' style=width:100px;height:45px onClick=location.href='/?on8;'><input type=submit value='5 OFF' style=width:100px;height:45px onClick=location.href='/?off9;'>
"<input type=submit value='6 ON' style=width:100px;height:45px onClick=location.href='/?on8;'><input type=submit value='6 OFF' style=width:100px;height:45px onClick=location.href='/?off9;'>
"<input type=submit value='7 ON' style=width:100px;height:45px onClick=location.href='/?on8;'><input type=submit value='7 OFF' style=width:100px;height:45px onClick=location.href='/?off9;'>
"<input type=submit value='8 ON' style=width:100px;height:45px onClick=location.href='/?on8;'><input type=submit value='8 OFF' style=width:100px;height:45px onClick=location.href='/?off9;'>
"</FORM>"
"</BODY>"
"</HTML>"
));   //end F() macro
         delay(1);
         //stopping client
         client.stop();
         if(readString.indexOf("5") >0)//checks for on
           digitalWrite(5, HIGH);    // set pin 5 high
           Serial.println(F("Led On"));
         if(readString.indexOf("50") >0)//checks for off
           digitalWrite(5, LOW);    // set pin 5 low
           Serial.println(F("Led Off"));
         if(readString.indexOf("6") >0)//checks for on
           digitalWrite(6, HIGH);    // set pin 6 high
           Serial.println(F("Led 6 On"));
         if(readString.indexOf("60") >0)//checks for off
           digitalWrite(6, LOW);    // set pin 6 low
           Serial.println(F("Led 6 Off"));
         if(readString.indexOf("7") >0)//checks for on
           digitalWrite(7, HIGH);    // set pin 7 high
         if(readString.indexOf("70") >0)//checks for off
           digitalWrite(7, LOW);    // set pin 7 low
         if(readString.indexOf("8") >0)//checks for on
           digitalWrite(8, HIGH);    // set pin 8 high
         if(readString.indexOf("80") >0)//checks for off
           digitalWrite(8, LOW);    // set pin 8 low
         //clearing string for next read
         readString="";
Hey guys,
thanks a lot, it has really been a SRAM problem as PaulS guessed or at least it is now working fine with the F() macro.
Is there a way to check the SRAM and print it to the serial console or something? I don't want to struggle around that problem again and agin ...
In best case I want to make myself a "checklist" if code is compiling but the results are not as expected check a) .... b) ... and so on
@surferTim: it works with as well as without your line of code, I cannot see any difference in the result.
Below is the code for those of you interested in how the code looks now.
#include <SPI.h>
#include <SD.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
// On the Ethernet Shield, CS is pin 4. Note that even if it's not used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library functions will not work.
// define the pin where the pump is attached to
int outputPin = 6;
int nTicks = 0;
int nBoundaryLow = 40;
int nBoundaryHigh = 60;
// (port 80 is default for HTTP):
// SD initializing
  Serial.println("Initializing SD card...");
  // make sure that the default chip select pin is set to output, even if you don't use it:
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
// ethernet initializing => start the Ethernet connection and the server:
  server.begin();
// other initializations
  nTicks ++;
  //read the sensor value
  // convert it to percentage => the value rage is 0-1023 => divide by 10,23
  //Serial.println(String(100-(sensorValue /10.23)));
  //First we write the values to the arduino
  // open the file. note that only one file can be open at a time, so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.print(nTicks);
    dataFile.print("; ");
    dataFile.print(sensorValue);
    dataFile.println(humidityPerCent);
    dataFile.close();
    Serial.println(String(nTicks) + "=>" + String(humidityPerCent));
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
 //This is for the Webserver to nicely display the status
  // listen for incoming clients
  if (client) {
    // an http request ends with a blank line
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline character) and the line is blank, the http request has ended,so you can send a reply
          // send a standard http response header
        client.println(F( "<!DOCTYPE HTML>"));
        client.println(F( "<html>"));
        client.println(F( "<head>"));
        client.println(F( "<title>The Garduino</title>"));
        client.println(F( "<style>"));
        client.println(F( "body, input, select, textarea"));
        client.println(F( "{color: #888;font: 16pt \"Source Sans Pro\", sans-serif; width: 75%; margin:0 auto;}"));
        client.println(F( ".gradient { height: 50px; margin: 0 0 50px 0;"));
          client.print(F( "background: -webkit-linear-gradient(left, #69482D 10%, #1B701B 45%, #1B701B 55%, #1E315E 90%);")); /* For Safari 5.1 to 6.0 */
          client.println(F( "background: -o-linear-gradient(right, #69482D 10%, #1B701B 45%, #1B701B 55%, #1E315E 90%);")); /* For Opera 11.1 to 12.0 */
          client.println(F( "background: -moz-linear-gradient(right, #69482D 10%, #1B701B 45%, #1B701B 55%, #1E315E 90%);")); /* For Firefox 3.6 to 15 */
          client.println(F( "background: linear-gradient(to right, #69482D 10%,#1B701B 45%, #1B701B 55%, #1E315E 90%);}")); /* Standard syntax (must be last) */
        client.println(F( ".box{float: left !important; height: 50px;}"));
         client.print(F( ".box.dry{width: "));
         client.print(nBoundaryLow);
        client.println(F( "%;}"));
         client.print(F( ".box.good{width: "));
         client.print(nBoundaryHigh-nBoundaryLow);
        client.println(F("%; border-left:2px solid #888; border-right:2px solid #888;}"));
        client.print(F( ".box.humid{width: "));
        client.print(100-nBoundaryHigh-3);
        client.println(F("%}"));
        client.println(F( ".level{text-align: right; height: 50px; border-right: 2.5px solid #444;}"));
        client.println(F( ".level.bad{border-right:2.5px solid #c33;}"));
        client.println(F( "</style>"));
        client.println(F( "</head>"));
        client.println(F( "<body>"));
        client.println(F( "<h1>The Garduino measures the humidity
of the ficus benjaminus</h1>"));
        client.println(F( "top soil sensor"));
        client.println(F( "<div class =\"gradient\">"));
        client.println(F( "<div class=\"box dry\">&nbsp;</div><div class=\"box good\">&nbsp;</div><div class=\"box humid\">&nbsp;</div>"));
        client.print(F( "<div class=\"level bad\" style=\"width:"));
        client.print(F( "%;\">"));
        client.print(humidityPerCent);
        client.print(F( "%</div>"));
        client.println(F( "</div>"));
        //*** END LOOP ***
        client.println(F( "</body>"));
        client.println(F("</html>"));
        if (c == '\n') {
          // you're starting a new line
          // you've gotten a character on the current line
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
With this function, you can measure the free SRAM on your board:
int freeRam () {
  extern int __heap_start, *__brkval;
  int v;
  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
thanks riesens! It worked fine for me, but in the meanwhile I upgraded to the 1.5x Version of the IDE which shows the used and left spaces. Many thanks.
The only weired and "funny" thing is, that if I use a "wrong" Power Plug (12V) my webserver sometimes gives back the weired output as mentioned in my first post and once I plug it to the USB Port it runs fine.
With the header, the request is correct. Without it, it is not correct, even though with some web browsers it may work ok.
