Looking for a little guidance and expertise on using the QMC5883 digital compasses. My interpretation of the datasheet () is that the unit returns the magnitude of the sensed field, in the x, y and z directions. I assumed then, that the squareroot of the sums of the squares of these values would represent the magnitude of the ambient B field.
In the field, I expected that when holding the unit approximately in the same position, the magnitude to be generally invariant to rotation - however that appears to be absolutely not the case: in-place rotation of the sensor can produce variations in the computed magnitude over an enormous range, of around four thousand (the unit is 18bit), while the noise with the unit approximately stationary is around 50.
I’ve been running barebones code (once from GitHub - dthain/QMC5883L: Driver for QMC5883L chip found in many GY-271 boards., and a different library from https://github.com/mprograms/QMC5883LCompass), and an example code showing calls to the library is shown below.
#include <Wire.h>
#include <MechaQMC5883.h>
MechaQMC5883 qmc;
Wire.begin();
qmc.init();
qmc.setMode(Mode_Continuous,ODR_200Hz,RNG_2G,OSR_256);
int x,y,z;
qmc.read(&x,&y,&z);
Serial.print(x);
Serial.print(",");
Serial.print(y);
Serial.print(",");
Serial.print(z);
Serial.print(",");
Serial.print(sqrt(pow(x,2)+pow(y,2)+pow(z,2)));
delay(10);
Is anyone able to correct my understanding of the way this unit works? I assumed I could compute the magnitude of the ambient magnetic field with the square root of the sums of the squares of the x, y and z components, but this appears to not be the case. Does anyone have a suggestion on how I SHOULD compute the magnitude of the B field, with this kind of unit?
Many thanks
