(deleted)
2.62.ino (21.7 KB)
(deleted)
2.62.ino (21.7 KB)
Interrupt service routines are intended to be as short as possible. Yours looks rather complex. Interrupts are suspended while processing your routine, which is a problem because you're trying to use millis for timing and it's driven by, you guessed it, an interrupt.
You need to rethink your use of interrupts.
(deleted)
(deleted)
Hello
wildbill:
....wich is a problem because you're trying to use millis for timing and it's driven by, you guessed it, an interrupt.
millis(); can be called in an ISR without problem , BUT millis() is stopped.
Regards,
bidouilleelec
To clarify what you said, bidouilleelec, you can call millis() to get a snapshot of when the ISR was called but you can't use it for timing loops etc. within the routine, correct?
Scottawildcat:
exactly
Scottawildcat:
Which is not a problem as you would not have any timing loops etc in an ISR.
if (stimmen = true)
I think you mean:
if (stimmen == true)
Or, since 'stimmen' is a boolean:
if (stimmen)
Check for '=' vs '==' in the rest of your code. It is a very common mistake.
Note: For the case of "if (boolVar == false)" it is shorter to say "if (!boolVar)".
