Interrupt Change Mode working only once.
Hello,
I am trying to program a project similar to a microwave, where the timer can be canceled at anytime by opening the door. I've figured using the attachInterrupt method is the best way of doing this. However, When I use the "CHANGE" mode of the attachInterrupt it only seems to register a single external input change from that pin.
For example, when I boot up the code and trigger the limit switch to signal a change, the program registers and prints "Door Closed" but any additional opening and closing of the door does not changed the statements. I've attached a simple version of what I'm dealing with.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
volatile int doorAction = 2;
volatile int doorState;
volatile int doorClosed;
int acvtivation = 0;
int completion = 0;
pinMode (doorAction, INPUT);
attachInterrupt(digitalPinToInterrupt(doorAction), ISR_doorAction, CHANGE);
lcd.begin(16,2);
if (doorClosed == true){
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("door is closed!");
delay(100);
else {
lcd.clear();
lcd.print("door is open!");
delay(100);
void ISR_doorAction () {
if (digitalRead(doorAction == LOW)) {
doorClosed = true;
else {
doorClosed = false;
At least this is wrong for reading a pin.
what is wrong with that and how would I do it correctly? doorAction is set to pin 2.
I could imagine you meant something like this:
if ( digitalRead(doorAction)  ==  LOW) {
instead of:
Notice the subtle reorganisation of the brackets.
Please review the reference page for correct usage of the digitalRead() function.
Please use code tags when posting code.
