Interrupt change
Hi, I have a push button on pin 13 of a 328P. I've been using the following code to change interrupt:
volatile long ticks = 0;
long oldticks=0;
SIGNAL(PCINT0_vect) {
  ticks++;
  digitalWrite(13,HIGH);
  pinMode(13, INPUT);
  PCMSK0 |= 32;
  PCICR |= 1;
  if (ticks>oldticks)
    oldticks=ticks;
    Serial.println("Interrupt");
First question: Is the interrupt change needed or there is another label for PCINT0_vect that applies to pin 13? Second question: What do I need to change to get the same thing on 2560?
Thanks, RI
Well, I looked in the 2560 datasheet and answered my own question... the pin 13 on 2560 is actually PCINT7. So changing this: PCMSK0 |= 32; to this: PCMSK0 |= 128; did the trick.
