Interrupt does not read stable
I have created a first testscript to start working with interrupts. I have uploaded the code below into my aruino uno (pin 2).
When I put a 5v current the ISR triggers once as it should be and works correct. The strange thing is, when I remove the 5V current I get new ISR calls serveral times and after a while it stops and the processing becomes stable again.
I'm I doing something wrong that triggers the ISR when the current is removed?
int pin = 2;
volatile int state = LOW;
  attachInterrupt(0, blink, HIGH);
  Serial.println(" loop......");
void blink()
 Serial.println("ISR ");
You do not do Serial.print() in an ISR
Read:
Probably do to a bouncy input.
So, any time pin 2 is HIGH, call the interrupt service routine?
Did you read anywhere that doing serial I/O in interrupt context was a Bad Ideatm, because serial output depends on interrupts, which are disabled in interrupt context?
Also it helps us to see a schematic and or image of your circuit.
