Well, it compiles fine on my computer, with my altered wiring_serial.c
Once I load it onto the Arduino, it doesn't do anything, though -- from poking at it it looks like it's not setting the values in DMX[] to anything, they just stay at their default value of 0. I haven't gone through it in detail, though.
Have you managed to receive DMX correctly with this code, under any version of the Arduino library?
If you want to compile it, here's what I did to wiring_serial.c (towards the end, there's a part that's commented out):
wiring_serial.c - serial functions.
Part of Arduino - http://www.arduino.cc/
Copyright (c) 2005-2006 David A. Mellis
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General
Public License along with this library; if not, write to the
Free Software Foundation, Inc., 59 Temple Place, Suite 330,
Boston, MA 02111-1307 USA
$Id: wiring.c 248 2007-02-03 15:36:30Z mellis $
Modified on March 1, 2009 by Norbert Pozar
#include "wiring_private.h"
// Define constants and variables for buffering incoming serial data. We're
// using a ring buffer (I think), in which rx_buffer_head is the index of the
// location to which to write the next incoming character and rx_buffer_tail
// is the index of the location from which to read.
// use only powers of 2 for the buffer size to produce optimal code
// 8, 16, 32, 64, 128 or 256
// input buffer
#define RX_BUFFER_SIZE 128
// output buffer
// set to 0 to disable the output buffer altogether (saves space)
#define TX_BUFFER_SIZE 32
unsigned char rx_buffer[RX_BUFFER_SIZE];
unsigned char rx_buffer_head = 0;
unsigned char rx_buffer_tail = 0;
void beginSerial(long baud)
#if defined(__AVR_ATmega8__)
UBRRH = ((F_CPU / 16 + baud / 2) / baud - 1) >> 8;
UBRRL = ((F_CPU / 16 + baud / 2) / baud - 1);
// enable rx and tx
sbi(UCSRB, RXEN);
sbi(UCSRB, TXEN);
// enable interrupt on complete reception of a byte
sbi(UCSRB, RXCIE);
#else
UBRR0H = ((F_CPU / 16 + baud / 2) / baud - 1) >> 8;
UBRR0L = ((F_CPU / 16 + baud / 2) / baud - 1);
// enable rx and tx
sbi(UCSR0B, RXEN0);
sbi(UCSR0B, TXEN0);
sbi(UCSR0B, RXCIE0);
#endif
// defaults to 8-bit, no parity, 1 stop bit
// advanced function, saves ~200 bytes because it doesn't use the long division
// prescaler for the baud rate can be found using the formula
// prescaler = fClock / (16 * baud rate) - 1
// see beginSerial
void beginSerialWithPrescaler(unsigned int prescaler)
UBRRH = prescaler >> 8;
UBRRL = prescaler;
// enable rx and tx
sbi(UCSRB, RXEN);
sbi(UCSRB, TXEN);
sbi(UCSRB, RXCIE);
#else
UBRR0H = prescaler >> 8;
UBRR0L = prescaler;
// enable rx and tx
sbi(UCSR0B, RXEN0);
sbi(UCSR0B, TXEN0);
#endif
int serialAvailable()
unsigned char i = RX_BUFFER_SIZE + rx_buffer_head - rx_buffer_tail;
i %= RX_BUFFER_SIZE;
return i;
int serialRead()
// if the head isn't ahead of the tail, we don't have any characters
if (rx_buffer_head == rx_buffer_tail) {
return -1;
unsigned char c = rx_buffer[rx_buffer_tail];
rx_buffer_tail = rx_buffer_tail + 1;
rx_buffer_tail %= RX_BUFFER_SIZE;
return c;
void serialFlush()
// don't reverse this or there may be problems if the RX interrupt
// occurs after reading the value of rx_buffer_head but before writing
// the value to rx_buffer_tail; the previous value of rx_buffer_head
// may be written to rx_buffer_tail, making it appear as if the buffer
// were full, not empty.
rx_buffer_head = rx_buffer_tail;
/* #if defined(__AVR_ATmega8__) *********THIS PART COMMENTED OUT*********
SIGNAL(SIG_UART_RECV)
#else
SIGNAL(USART_RX_vect)
#endif
unsigned char c = UDR;
#else
unsigned char c = UDR0;
#endif
unsigned char i = rx_buffer_head + 1;
// if we should be storing the received character into the location
// just before the tail (meaning that the head would advance to the
// current location of the tail), we're about to overflow the buffer
// and so we don't write the character or advance the head.
if (i != rx_buffer_tail) {
rx_buffer[rx_buffer_head] = c;
rx_buffer_head = i;
// buffered output
#if (TX_BUFFER_SIZE > 0 )
// TX is buffered
// tested only for ATmega168
unsigned char tx_buffer[TX_BUFFER_SIZE];
unsigned char tx_buffer_head = 0;
volatile unsigned char tx_buffer_tail = 0;
// interrupt called on Data Register Empty
SIGNAL(SIG_UART_DATA)
#else
SIGNAL(USART_UDRE_vect)
#endif
// temporary tx_buffer_tail
// (to optimize for volatile, there are no interrupts inside an interrupt routine)
unsigned char tail = tx_buffer_tail;
// get a byte from the buffer
unsigned char c = tx_buffer[tail];
// send the byte
UDR = c;
#else
UDR0 = c;
#endif
// update tail position
tail ++;
tail %= TX_BUFFER_SIZE;
// if the buffer is empty, disable the interrupt
if (tail == tx_buffer_head) {
UCSRB &= ~(1 << UDRIE);
#else
UCSR0B &= ~(1 << UDRIE0);
#endif
tx_buffer_tail = tail;
void serialWrite(unsigned char c) {
if ((!(UCSRA & (1 << UDRE)))
#else
if ((!(UCSR0A & (1 << UDRE0)))
#endif
|| (tx_buffer_head != tx_buffer_tail)) {
// maybe checking if buffer is empty is not necessary,
// not sure if there can be a state when the data register empty flag is set
// and read here without the interrupt being executed
// well, it shouldn't happen, right?
// data register is not empty, use the buffer
unsigned char newhead = tx_buffer_head + 1;
newhead %= TX_BUFFER_SIZE;
// wait until there's a space in the buffer
while (newhead == tx_buffer_tail) ;
tx_buffer[tx_buffer_head] = c;
tx_buffer_head = newhead;
// enable the Data Register Empty Interrupt
UCSRB |= (1 << UDRIE);
#else
UCSR0B |= (1 << UDRIE0);
#endif
else {
// no need to wait
UDR = c;
#else
UDR0 = c;
#endif
#else
// unbuffered write
while (!(UCSRA & (1 << UDRE)))
UDR = c;
#else
while (!(UCSR0A & (1 << UDRE0)))
UDR0 = c;
#endif
#endif
