Interrupt / EEPROM question
Hello, If I want to write something to EEPROM, Should I disable interrupts or arduino does it automatically for me ?
Thank you for your answer.
If you are planning to use the Arduino EEPROM library, no manipulation of interrupts is needed. This library uses a simple polled approach, as opposed to interrupt-controlled EEPROM access. Just out of curiosity, why did you think interrupts needed to be disabled?
I thought writing the EEPROM must be continuous without interruption. Thank you for your answer.
I'm thinking the hardware probably handles it asynchronously.
