Hello, Is it possible to put an interrupt on data reception from client with an ethernet shield. Now I look "if (client.available())" and it works but I want to know if this can create an interrupt. Thanks
Why do you want to? Generally interrupt routines should be kept short, and thus you would just set a flag. So now instead of:
you would have:
if (flag_set)
Which hasn't saved much.
Hello,
Thanks for your answer. I will give more details :
I have differents loop fonctions which generate sinusoidals, triangles, square… signals and these fonctions must be very short to obtain the frequence I need.
So when I look in my loop fonction if(client.available()) and datas received I lose time.
The signal stop command is sent by a computer and my idea was to set a flag in an interrupt for example to stop signal.
What Ethernet shield or board are you using ?
This one http://arduino.cc/en/Main/ArduinoEthernetShield "allows the Arduino board to receive interrupt-driven notification of events from the W5100"
However, note the comment "but this is not supported by the Ethernet library"
Yes it's this one. So How to recover interrupt-driven notification of events from the W5100 ? On link you post I read "The jumper connects the INT pin of the W5100 to digital pin 2 of the Arduino. " It means I just have to code an interrupt on Pin2 like an external interrupt ? What's this jumper ??? I don't see jumper on my ethernet board and on photo.
It looks like other people have had the same problem http://arduino.cc/forum/index.php/topic,89615.0.html
Ok thanks a lot
