Interrupt from sleep mode
I have an Arduino Uno connected to a breadboard on pin #3 and a 10k resistor and the 3.3v pin.
I then installed a button in between them so I can represent a break in the connection to fire the interrupt.
Trouble is the button does not seem to fire the interrupt at all. If I remove the 3.3v wire so that it floats on pin #3 then it wakes up.
Any ideas why I cannot seem to get it to recognize the break in connection?
Sketch attached
test.ino (1 KB)
You need to switch the pin to ground if you are using a pull-up resistor, not break the link to the pull-up.
The point is to avoid the pin floating ever, since it isn't defined if its floating, the behaviour is unpredicatable.
So with pin 3 connected to 5V via a resistor, add button between pin 3 and GND.
You could lose the resistor and declare the pin with internal pull-up enabled:
void setup ()
  pinMode (3, INPUT_PULLUP) ;
My main goal is to connect it to a LED from another device and when that device lits up the LED it will wake up and perform an action. That is why I attempted to use 3.3v instead of ground.
What I'm unsure of the following statement?
Are you saying to remove it from 5v and put it only to ground? FYI I've attempted this and it didn't do anything. Although I didn't code it pinMode INPUT_PULLUP. I presume I can do this and still attach the interrupt on pin 3?
Sorry for the newbie questions
use FALLING, not RISING if the signal is active low.
