Interrupt function causes the IWDT to time out on esp32
Everytime the interrupt function starts to count the number of incoming HIGHs from the encoder (in the void isr() ), I get a IWDT time out.
(Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
Can someone check my code to see what could cause this?
Thanks in advance!
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#include <EEPROM.h>
#define EEPROM_SIZE 1
// #define GPIO 2 (dit is voor de esp8266)
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
// Motor A
int motor1Pin1 = 27;
int motor1Pin2 = 26;
int ENA = 25;
int encoder = 13;
volatile int counter;
int currentValue = 0;
int previousValue = 0;
int openingRotations;
int TurnMotorBack;
long OpeningDelay = 0;
long Factor = 1000000;
long Day = 86400;
RTC_DATA_ATTR int bootCount = 0;
// Setting PWM properties
const int freq = 85000;
const int pwmChannel = 0;
const int resolution = 8;
int dutyCycle = 200;
class MyCallbacks : public BLECharacteristicCallbacks {
  void onWrite(BLECharacteristic *pCharacteristic) {
    std::string value = pCharacteristic->getValue();
    if (value.length() > 0) {
      for (int i = 0; i < value.length(); i++) {
        Serial.print(value[i]);
      if (isDigit(value[1])) {
      OpeningDelay = (value[0]*10L*3600L + value[1]*3600L + value[2]*10L*60L + value[3]*60L - 1932480L); // for some reason the number 1932480 is the starting value
      Serial.println(OpeningDelay);
      //Calibration of number of rotations motor
      if (value.find("OpenCurtain") != -1) {
        Serial.println("Open Curtain");
        digitalWrite(motor1Pin1, LOW);
        digitalWrite(motor1Pin2, HIGH);
      } else if (value.find("StopMotor") != -1) {
        Serial.println("Stop motor!");
        digitalWrite(motor1Pin2, LOW);
        openingRotations = counter;
        EEPROM.write(0, openingRotations);
        EEPROM.commit();
        counter = 0;
        Serial.println(openingRotations);
        delay(2000);
        digitalWrite(motor1Pin1, HIGH);
      else if (value.find("Complete") != -1) {
         Serial.println("Going to sleep for the 1 time");
          bootCount = bootCount +1;
          digitalWrite(15,LOW); // power OFF encoder before deepsleep
          esp_sleep_enable_timer_wakeup(90000000L);  //OpeningDelay*Factor
          esp_deep_sleep_start();
  EEPROM.begin(EEPROM_SIZE); // initialize EEPROM with predefined size (flashmemory)
  pinMode(15, OUTPUT);
    digitalWrite(15,HIGH); // power to encoder
  pinMode(motor1Pin1, OUTPUT);
  pinMode(motor1Pin2, OUTPUT);
  pinMode(ENA, OUTPUT);
  pinMode(encoder, INPUT);
  attachInterrupt(13, isr, RISING);
  //pinMode(GPIO, OUTPUT);
  //  digitalWrite(GPIO, HIGH); // disable power led (dit is voor de ESP8266)
  // configure LED PWM functionalitites
  ledcSetup(pwmChannel, freq, resolution);
  // attach the channel to the GPIO to be controlled
  ledcAttachPin(ENA, pwmChannel);
  ledcWrite(pwmChannel, 200);
  BLEDevice::init("CrouzeSystem");
  BLEServer *pServer = BLEDevice::createServer();
  BLEService *pService = pServer->createService(SERVICE_UUID);
  BLECharacteristic *pCharacteristic = pService->createCharacteristic(
    CHARACTERISTIC_UUID,
    BLECharacteristic::PROPERTY_READ | BLECharacteristic::PROPERTY_WRITE);
  pCharacteristic->setCallbacks(new MyCallbacks());
  pService->start();
  BLEAdvertising *pAdvertising = pServer->getAdvertising();
  pAdvertising->start();
 // Curtains opens every 24h and goes back to deepsleep
if (bootCount != 0){
  delay(300);
  Serial.println("Boot number: " + String(bootCount));
  openingRotations = EEPROM.read(0);
  Serial.println("opening rotations: " + openingRotations);
  counter = 0;
  if (counter >= openingRotations){
      counter = 0;
          counter = 0;
          esp_sleep_enable_timer_wakeup(Day*Factor); // Ik kan de esp32 enkel 24h laten slapen door 24 x 1 uur te laten slapen (nog te fiksen)
delay(300);
void isr() {
  // calibration counter
  currentValue = digitalRead(encoder);
  if (currentValue != previousValue) {
    if (currentValue == 1) {
      counter++;
      Serial.println(counter);
  previousValue = currentValue;
  TurnMotorBack = digitalRead(motor1Pin1);
  if (counter >= openingRotations && TurnMotorBack == HIGH) {
    counter = 0;
void isr() {
      counter++;
is your issue?
void IRAM_ATTR isr()
What happens when you do
void IRAM_ATTR isr() {
  //currentValue = digitalRead(encoder);
  //if (currentValue != previousValue) {
   // if (currentValue == 1) {
    //  counter++;
    //  Serial.println(counter);
  //previousValue = currentValue;
    //  counter++;
    //  counter++;
and so on and so forth?
Why serial print for an ISR?
What happens when you put the debug info into the ESP Exception Decoder?
Thank you! I got it to work.
I remembered the problem started to occur when I changed computers. I deinstalled arduino IDE on my new computer and reinstalled it. Now it works again.
