Dear all,
i am currently trying to setup a rotation speed calculation for a small DC motor. I am using:
- ESP8266 nodemcu v3
- 12 V DC Motor
- Hall sensor ("Hall switch")
- Small magnet in the DC Motor shaft
I wrote / copied the following code:
const uint8_t interruptPin = 5; //D1
volatile byte interruptCounter = 0;
volatile unsigned int isrMillis;
int numberOfInterrupts = 0;
int rpm = 0;
unsigned int timeold;
void ICACHE_RAM_ATTR handleInterrupt();
pinMode(interruptPin, INPUT);
attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterrupt, FALLING);
void handleInterrupt() {
interruptCounter++;
isrMillis = millis();
if(interruptCounter>0){
interruptCounter--;
numberOfInterrupts++;
Serial.print("Total: ");
Serial.print(numberOfInterrupts);
Serial.print(" // Time: ");
Serial.print(isrMillis-timeold);
Serial.print(" // RPM: ");
//rpm = 1/((isrMillis-timeold)/(60*100));
Serial.println(rpm);
timeold = millis();
This code seems to work fine:
14:31:48.545 -> Total: 2 // Time: 528 // RPM: 0
14:31:49.062 -> Total: 3 // Time: 527 // RPM: 0
14:31:49.609 -> Total: 4 // Time: 527 // RPM: 0
14:31:50.120 -> Total: 5 // Time: 525 // RPM: 0
14:31:50.665 -> Total: 6 // Time: 524 // RPM: 0
14:31:51.179 -> Total: 7 // Time: 524 // RPM: 0
14:31:51.688 -> Total: 8 // Time: 526 // RPM: 0
14:31:52.237 -> Total: 9 // Time: 528 // RPM: 0
However when i do uncomment the engine speed calculation
i am getting this:
16:19:13.006 -> Total: 1 // Time: 80247 // RPM: 0
16:19:13.517 -> Total: 2 // Time: 536 // RPM:
16:19:13.552 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
16:19:13.621 ->
16:19:13.621 -> Exception (0):
16:19:13.655 -> epc1=0x4000e25d epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
16:19:13.723 ->
16:19:13.723 -> >>>stack>>>
16:19:13.757 ->
16:19:13.757 -> ctx: cont
16:19:13.757 -> sp: 3ffffe00 end: 3fffffc0 offset: 0190
16:19:13.791 -> 3fffff90: 3fffdad0 00000000 3ffee360 402010e8
16:19:13.860 -> 3fffffa0: 3fffdad0 00000000 3ffee360 40201afc
16:19:13.894 -> 3fffffb0: feefeffe feefeffe 3ffe84e0 40100d31
16:19:13.963 -> <<<stack<<<
16:19:13.963 ->
16:19:13.963 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
16:19:14.064 -> ⸮B⸮⸮⸮⸮
Can someone help?
I got a message like this already at the beginning of playing with interrupts and was able to solve it by this line:
Now it seems to be broken again...
