noldar
October 13, 2022, 2:22pm
1
Hi
I would like to read an Incremental-Encoder.
To do this, I use an ISR for the two Encode-Pins (Clock and Data)
My code below works, but not reliably.
EG: If I turn the know counterclockwise, the read value changes between 0 and 1.
I suspect a missing interrupt enable/disable like cli() and sei() in the ISR routine.
I tryed successless to manage it with noInterrupt() and interrupt().
But maybe the problem is somewhere else.
Many thanks for an advice.
#define ClockPin 6 //Incremental Encoder
#define DataPin 5 //Incremental Encoder
volatile uint8_t Speed=0;
uint8_t oldSpeed=0;
volatile uint8_t CurrentStateClock=0;
volatile uint8_t StateData=0;
volatile uint8_t LastStateClock=0;
{ Serial.begin(9600);
pinMode(ClockPin, INPUT_PULLUP);
pinMode(DataPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(ClockPin), SpeedISR, CHANGE);
attachInterrupt(digitalPinToInterrupt(DataPin), SpeedISR, CHANGE);
// Same behavior with FALLING
LastStateClock = digitalRead(ClockPin); //Init
{ if(oldSpeed != Speed)
{ Serial.println(Speed);
oldSpeed=Speed;
void SpeedISR()
{ CurrentStateClock = digitalRead(ClockPin);
StateData = digitalRead(DataPin);
if (CurrentStateClock != LastStateClock)
{ if (StateData != CurrentStateClock) //Rotating clockwise
{ if (Speed < 24) Speed++;
LastStateClock = CurrentStateClock;
else //Rotating counterclockwise
{ if (Speed > 0) Speed--;
Please post a link to the incremental encoder data sheet.
noldar
October 13, 2022, 2:47pm
3
I'm using this IncrementalEncoder:
PEC11R-4215F-S0024 - Incremental Encoder 24 PPR ... 5V 60min-1, Bourns
BTW : Maybe the problem is the digitalRead() within an ISR?
That looks to be a standard quadrature encoder. I suggest to use the Arduino encoder library.
Wire it according to the schematic diagram in the data sheet, to reduce switch bounce.
Those function calls are almost never useful in an ISR.
We need to know which Arduino you are using. The interrupt options that are available depend on the choice of processor pin.
noldar
October 13, 2022, 3:20pm
5
Sorry I forgot to mention it:
ATSAMD21G18 ARM Cortex M0
( Adafruit Feather M0 RFM69 Packet Radio)
This test is true only if the clock pin changes. The data pin interrupt cannot do anything and can be omitted.
This update should occur always, not only under certain conditions.
noldar
October 15, 2022, 6:57am
7
I have modified my SAMD21-Code , and yes, I'll add 10nF-debouncing-caps as soon as I am within reach of a soldering iron. But for now: debouncing has to be done by software:
#define CHNApin 6 //Inkrementalgeber Channel-A
#define CHNBpin 5 //Inkrementalgeber Channel-B
#define TimeoutEncoder 50 //Debouncing-Timer Timeout
volatile unsigned long CHNApinDebouncing=0; //Debouncing-Timer
volatile unsigned long CHNBpinDebouncing=0; //Debouncing-Timer
{ Serial.begin(115200);
pinMode(CHNApin, INPUT_PULLUP);
pinMode(CHNBpin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(CHNApin), CHNApinISR, FALLING);
attachInterrupt(digitalPinToInterrupt(CHNBpin), CHNBpinISR, FALLING);
void loop() { }
void CHNApinISR()
{ if((millis() - CHNApinDebouncing) > TimeoutEncoder) //Debouncing-TimeOut zum Tasten entprellen
{ CHNApinDebouncing = millis();
if(digitalRead(CHNBpin)==1)
Serial.print("X");
void CHNBpinISR()
{ if((millis() - CHNBpinDebouncing) > TimeoutEncoder) //Debouncing-TimeOut zum Tasten entprellen
{ CHNBpinDebouncing = millis();
if(digitalRead(CHNApin)==1)
Serial.print("-");
For turning the encoder clockwise (more or less constantly 1rps) , the result is instead of XXXXXXXXXXX... e.g. XXXXXXXXX-XXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XX-XXXXXXXXXX (non reproducible), what means, there are in a seemingly random order counterclockwise signals (-).
In my opinion, bouncing and Serial.print() (uC-Timing) should not be the problem.
This is a problem! Don't print anything in an ISR.
noldar
October 15, 2022, 7:25am
9
OK, done:
#define CHNApin 6 //Encoder Channel-A
#define CHNBpin 5 //Encoder Channel-B
#define TimeoutEncoder 50 //Debouncing-TimeOut
volatile long Counter=0;
long lCounter=-1;
{ if(Counter != lCounter)
{ Serial.println(Counter);
lCounter=Counter;
void CHNApinISR()
Counter++;
void CHNBpinISR()
Counter--;
And the same flickering...
Disable interrupts while reading Counter .
noldar
October 15, 2022, 7:53am
11
(Thanks DrDiettrich for your help)
OK, done:
#define DebouncingTimeout 50 //Debouncing-TimeOut
volatile unsigned long CHNADebouncing=0; //DebouncingTimer Channel-A
volatile unsigned long CHNBDebouncing=0; //DebouncingTimer Channel-B
long lCounter=-1;
attachInterrupt(digitalPinToInterrupt(CHNApin), EncoderCHNA_ISR, FALLING);
attachInterrupt(digitalPinToInterrupt(CHNBpin), EncoderCHNB_ISR, FALLING);
lCounter=Counter;
void EncoderCHNA_ISR()
{ noInterrupts();
if((millis() - CHNADebouncing) > DebouncingTimeout)
{ CHNADebouncing = millis();
Counter++;
interrupts();
void EncoderCHNB_ISR()
{ noInterrupts();
if((millis() - CHNBDebouncing) > DebouncingTimeout)
{ CHNBDebouncing = millis();
Counter--;
interrupts();
Same behavior.
But basically you agree with me?
If you only look at the clockwise direction:
The first time a negative edge occurs on channel A and inactive channel B, this means increasing the counter.
I don't see when the state that evokes counterclockwise behavior occurs.
Interrupts already are disabled in the ISR.
In the other ISR. With opposite direction raising and falling edges are exchanged.
noldar
October 15, 2022, 8:20am
13
You wrote: In the other ISR. With opposite direction raising and falling edges are exchanged.
But both, Channel-A and Channel B generate falling signaledges when they activated, because they switch to GND
And my ISR's only evaluate falling signaledges. (!?)
if the encoder stops after a raising edge and then rotates back the same edge is a falling one.
noldar
October 15, 2022, 11:31am
15
Sorry DrDiettrich, I don't see the error:
noldar
October 15, 2022, 2:36pm
16
Another version which not correct works:
volatile uint8_t CHNAexpected=1; //1=>CHNAexpected 0=>CHNBexpected
long lCounter=-1;
//2-Bit Quadraturcode IncrementalEncoder Bourns PEC11R-4215F-S0024
//24 Pulses per Fullrotation, 24 Detent, ContactBounce(15RPM max.2ms, RPM max.60
lCounter=Counter;
{ if(CHNAexpected)
{ CHNAexpected=0;
if(Counter<24)
Counter++;
{ if(!CHNAexpected)
{ CHNAexpected=1;
if(Counter>0)
Counter--;
noldar:
And I don't see your problem:
If there still is a problem then please explain.
Most probably you are fighting too many effects at a time. Everything were easier if you replaced your encoder by an optical one which can not bounce.
This is guaranteed to fail on occasion:
You must disable interrupts when reading a variable shared with an interrupt routine, or it WILL be corrupted. As follows
noInterrupts();
long count_copy = Counter;
interrupts();
Serial.println(count_copy);
lCounter = count_copy;
Or just substitute lCounter for count_copy.
noldar
October 15, 2022, 4:54pm
19
Thank you very much DrDiettrich for taking the time for my problem.
It's a pleasure for me to explain:
Felt like millions of producers successful use the cheaper version of the incremental switch-encoder instead of the optical one.
The poblem with the current version is the flickering around the zero-value
The Theory as shown in the diagram in post #15 should be right (Falling/Rising). Agree?
My workaraund without flickering arround zero for now, is to count to 48 instead of 24 an divide the result by 2. This is accurate enough for my application, a replacement for a Potentiometer which controlls the speed of a toyengine.
noldar
October 15, 2022, 5:07pm
20
Thank you jremington for your help.
I replaced my loop-Function as follows:
{ noInterrupts();
interrupts();
And the result: Unfortunately the same behavior as bevor
