Interrupt Handling with Arduino Atmega 328
i am trying to use this code :
byte n = 0;						                // Interrupt Bit Count
volatile byte pos = 0;						// Values Position Count
volatile byte values[5] = {
  0,0,0,0,0};		                                                // Values to be stored by sensor
byte cbit = 0;						        // Current bit read in
boolean irFlag = false;						// Flag to indicate IR reading has been made
boolean ambFlag = false;					// Flag to indicate ambient temp reading has been made
byte irValues[5] = {
  0,0,0,0,0};				                               // Variable to store IR readings
byte ambValues[5] = {
  0,0,0,0,0};			                                      // Variable to store Ambient readings
const int len = 5;					              // Length of values array
const int clkPin = 3;			                      // Pins
const int dataPin = 2;
const int actionPin = 4;
void setup(){
  pinMode(clkPin, INPUT);					// Initialize pins
  pinMode(dataPin, INPUT);
  pinMode(actionPin, OUTPUT);
  digitalWrite(clkPin, HIGH);
  digitalWrite(dataPin, HIGH);
  digitalWrite(actionPin, HIGH);
  Serial.println("Type to Start...");		                // Wait for input to start
  while(!Serial.available());
  Serial.println("Starting...");
  Serial.println("IR (C), Ambient (C), Time Since Start (ms)");
  attachInterrupt(1,tn9Data,FALLING);  		        // Interrupt
  digitalWrite(actionPin,LOW);			  	// Make sensor start sending data
void loop(){
  if(pos == len && values[0] == 0x4C){		        // If sensor has sent IR packet...
    for(int i = 0; i < len; i++){			                // Store values to irValues
      irValues[i] = values[i];
    irFlag = true;				                       // Indicate IR reading
    pos = 0;
  if(pos == len && values[0] == 0x66){		      // If sensor has sent ambient packet...
    for(int i = 0; i < len; i++){			              // Store values to ambValues
      ambValues[i] = values[i];
    ambFlag = true;				              // Indicate Ambient reading
    pos = 0;
  if(pos == len && values[0] == 0x53){		     // If sensor has sent junk packet
    pos = 0;
  if(irFlag && ambFlag){				// If successful IR and Ambient reading...
    digitalWrite(actionPin,HIGH);		// Make sensor stop sending data.  Because Timing is weird, I want to ensure the interrupts do not happen during this section.
    word tempword = 0;  			// Next 4 lines isolate temperature component of values
    tempword = tempword | irValues[1];
    tempword = tempword << 8;
    tempword = tempword | irValues[2];
    if(tn9Check(irValues)){				// If checksum is valid, print IR temperature
      //Serial.print("IR = ");
      Serial.print(int(tempword)/16.0 - 273.15);
      Serial.print(", ");
    else{					        // If checksum isn't valid, print impossible temp
      Serial.print("-273.15, ");
    tempword = 0;					// Isolate temperature component again for ambient
    tempword = tempword | ambValues[1];
    tempword = tempword | ambValues[2];
    if(tn9Check(ambValues)){				// If checksum is valid, print ambient temperature
      //Serial.print("Amb = ");
      Serial.print("-273.15");
    irFlag = false;					// Reset flags
    ambFlag = false;
    Serial.print(", ");
    Serial.println(millis());                           // Print time for logging purposes
    delay(2000);					     // Simulate other sensors or code
void tn9Data(){						// Interrupt Function
  cbit =  digitalRead(dataPin);			// Read bit
  if(pos >= len) pos = 0;				        // Keep index below 5
  values[pos] = (values[pos] << 1) | cbit;	        // Store to values
  n++;							// Increment bit count
  if(n == 8){						// Increment position count based on bits read in
    pos++;
    n = 0;
  if(pos == len){ 					// If complete "packet" sent, stop sensor from sending
    digitalWrite(actionPin,HIGH);  		// again until main loop allows it.
boolean tn9Check(byte tn9Values[]){			// Checksum calculating function
  int mcheck = (int)tn9Values[0] + (int)tn9Values[1] + (int)tn9Values[2];	// Checksum calculation
  int scheck = (int)tn9Values[3];			       // Checksum sent by sensor
  boolean crc = false;						// Initialize return value
  if(mcheck > 510) mcheck = mcheck - 512;	        // Handle sensor byte rollover
  if(mcheck > 255) mcheck = mcheck - 256;	        // Handle sensor byte rollover
  if(mcheck == scheck) crc = true;			// Check checksum
  return(crc);						// Return
I tested it with a Mega 2560 and it works fine but if i use the same pins and a Atmel 328 SMD-Kit from Jeelabs http://jeelabs.com/products/smd-kit
It is not working. Could it be an interrupt problem?
Can someone please help me? Where are the difference between Mega 2560 and Atmel 328?
I got the code from this post: http://forum.arduino.cc/index.php?topic=84705.0
Thanks a lot.
Cu kami
Interrupts explained well:
Click on any board on this page to get board-specific information.
Choose your pois... errr, chip and get the datasheet on the Atmel site!
http://www.atmel.com/devices/ATMEGA328P.aspx
The 35MB 660 page pdf is the definitive 328P doc.
i just found out something new. The Code is only working on my 2560 Board, when i upload it for the first time. After disconnecting the power and restarting i just get the message of the Serial console but no new values. Only after uploading the code it works?
Why can someone help me?
Cu kami
Is the sensor still wired correctly? Because the code should work the same.
Did you look at the pin maps for the UNO and MEGA boards? The UNO uses a 328 chip.
