Looking for some assistance on a sketch to record wind speed from an annemometer. The annemometer switches to ground each revolution of the cups.
I am trying to use an interrupt function because the initial code I had seems to be missing pulses (the switch only goes to ground momentarilty on each revolution)
This is what I have so far.
Wind speed read from switch to ground on Pin 2
//Wind Speed Constants
int LastState = 0;
int SensorTime = 0; // Time at wind speed falling edge
int PrevSensorTime = 0; // Previous time at wind speed falling edge
long period = 0; // Period of windspeed square wave in milliseconds
float AppWindSpeed = 0; // Windspeed in knots
#define SpeedSensor 2 //Switch to ground
pinMode(SpeedSensor, INPUT_PULLUP);
attachInterrupt(SpeedSensor, WindSpeed, FALLING);
//OUTPUT DATA TO SCREEN
Serial.print(" Apparent Wind Speed = ");
Serial.print(AppWindSpeed);
Serial.println(" Knots");
delay (1); // Delay 1 millisecond for stability
void WindSpeed()
SensorTime = millis(); //Read time of change
period = SensorTime - PrevSensorTime; //Calculate time since last change
PrevSensorTime = SensorTime; //Set current sensor time as previous time for next reading
AppWindSpeed = 1955.20 / period; //convert from period to frequency and then to knots
It compiles OK but i get silly windspeed readings like around 100knots when i would expect 5 or 10.
You are setting the interrupt to 2 (speedSensor). If your speed sensor is connected to pin 2 the interrupt would be 0. There are two external interrupts pin 2 is interrupt 0 and pin 3 is interrupt 1 on a Uno.
What is the nature of the switch in the anemometer? If it's anything mechanical, e.g. a reed switch, there will be switch bounce to deal with. That may be what is causing it to look like it's closing more often than reasonable. I'd estimate the minimum expected period based on the maximum wind speed to be measured, then use that for some debouncing code.
I am using an Arduino Micro, as I read it the interrupt pins are 0, 1, 2 and 3 but the Arduino site does not refer to what the interrupt numbers are for these pins so I have assumed the interrupt no is the pin no is that correct???
The sensor has a magnet rotating against a sensor so i assume it is a Hall effect sensor, would these be susceptible to bounce like a reed switch?
Your main loop is flooding the serial port set at low speed. I'm not sure if this effects your timing, but it should be changed.
Use a higher baud rate and longer delay.
Keep a running average of results and report every nth cycle.
Maintain a running count of the interrupt pulses and report pulses/sec as a debugging tool. If the pulse count is too high than you may have a bounce problem. It is always better to measure than to guess.
