May be you can help me. I'm looking for use a interrupt with a function inside a class, but the attachInterrupt instruction is inside of the same class.
Can you help me? I paste the class.h and class.cpp
The error code is:
Encoder.cpp:13:43: error: argument of type ‘void (RotaryEncoder::)()’ does not match ‘void (*)()’
#include "Encoder.h"
RotaryEncoder::RotaryEncoder (uint8_t PinA, uint8_t PinB)
encoderPin1 = PinA;
encoderPin2 = PinB;
pinMode(encoderPin1, INPUT);
pinMode(encoderPin2, INPUT);
//call updateEncoder() when any high/low changed seen
//on interrupt 0 (pin 2), or interrupt 1 (pin 3)
attachInterrupt(0, UpdateEncoder, CHANGE);
attachInterrupt(1, UpdateEncoder, CHANGE);
void RotaryEncoder::UpdateEncoder (void) {
uint8_t encoded = (digitalRead(encoderPin1) << 1) | digitalRead(encoderPin2); //converting the 2 pin value to single number
uint8_t sum = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) Variable ++;
if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) Variable --;
lastEncoded = encoded; //store this value for next time
I'm not sure of the way around this but (i suspect) your problem is this that's the extra parameter added to a C++ method when its translated to a c function.
The usual way around it is to have a function outside your class which then calls the function inside the class. The interrupt is then bound to that outer function.
You can't do this directly. You are trying to pass a "pointer to a member function" to attachInterrupt(), which takes a "pointer to a function" as an argument. Yes, there is a difference.
As majenko pointed out, you can use an external function, or, I would prefer a static function to solve this issue.
