Interrupt LED "Program" with MQTT message
Hi!
I’m very new to this forum so I’m not sure if I’m posting in the right place, please let me know.
HARDWARE:
2x ESP32-WROOM-32 (DOIT ESP32 DEVKIT V1)
2x WS2812 LED Rings
SOFTWARE:
MQTT Server - PubNub - www.pubnub.com
When it senses a touch, my program sends an MQTT message to a server on which both boards are subscribed to. The boards read from the server and when a message arrives, they switch the current LED “mode” to the next one. The LED “modes” are either full-color mode or rainbow mode. The rainbow() function was taken from the Library Examples. The problem arises when the rainbow() loop is running, I want that to run continuously when selected, and then when an MQTT message arrives, I want it to cycle back to full-color mode.
Hence, my question is: How would go about running a loop in which LED’s change and have it be interrupted solely by an MQTT message?
I’ve tried to put client.loop() inside of the rainbow() for-loop but that did not do what I wanted.
Redacted code:
#include <WiFi.h>
#include <PubSubClient.h>
long lastReconnectAttempt = 0;
const char* ssid = "ssid";
const char* password =  "pass";
const char* mqttServer = "mqtt.pndsn.com";
const int mqttPort = 1883;
const char* clientID = "pub_auth/sub_auth/board0";
const char* channelName = "this_is_a_test";
WiFiClient MQTTclient;
PubSubClient client(MQTTclient);
long lastTouch = -1;
long currentTouch = -1;
boolean activeTouch = false;
const int colors[6][3] = {
  {149, 33, 246},   // PURPLE
  {255, 0, 0},      // RED
  {0, 255, 0},      // GREEN
  {0, 0, 255},      // BLUE
  {255, 195, 11},   // YELLOW
  {255, 255, 250}   // WHITE
int colorID = 0;
#define LED_PIN 13
#define LED_COUNT 24
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
void callback(char* topic, byte* payload, unsigned int length) {
  String payload_buff;
  for (int i = 0; i < length; i++) {
    payload_buff = payload_buff + String((char)payload[i]);
  Serial.print(payload_buff);
  colorID = (colorID + 1) % 7;
  if (colorID < 6) { //If full colors then change it here, else go in loop() and run the rainbow there
    uint32_t newColor = strip.Color(colors[colorID][0], colors[colorID][1], colors[colorID][2]);
    for (int i = 0; i < strip.numPixels(); i++) {
      strip.setPixelColor(i, newColor);
    strip.show();
boolean reconnect() {
  if (client.connect(clientID)) {
    client.subscribe(channelName); // Subscribe to channel.
  return client.connected();
  Serial.println("Attempting to connect...");
  WiFi.begin(ssid, password); // Connect to WiFi.
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("Couldn't connect to WiFi.");
    while (1) delay(100);
  client.setServer(mqttServer, mqttPort); // Connect to PubNub.
  client.setCallback(callback);
  strip.begin();
  strip.show();
  strip.setBrightness(10);
  if (!client.connected()) {
    long now = millis();
    if (now - lastReconnectAttempt > 5000) { // Try to reconnect.
      lastReconnectAttempt = now;
      if (reconnect()) { // Attempt to reconnect.
  } else { // Connected.
    long timeSinceBoardStart = millis();
    int touchValue = touchRead(T0);
    if (touchValue < 25) {
      if (activeTouch) {
        currentTouch = timeSinceBoardStart;
      if (!activeTouch) {
        activeTouch = true;
        lastTouch = timeSinceBoardStart;
        int diff =  lastTouch - currentTouch;
        if (diff > 50 && diff <= 800) { // If the touch was between 50 and 800 ms, then send a message to server
          Serial.print("This was a tap!");
          //client.publish(channelName, ColorIDString.c_str()); // Publish message.
      if (colorID == 6) {
        rainbow();
  client.loop();
  delay(50);
void rainbow() {
  for (long firstPixelHue = 0; firstPixelHue < 5 * 65536; firstPixelHue += 256) {
      int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
      strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
    strip.show();
    delay(10);
Using an ESP32, perhaps a rethink of how you are doing the thing could be in order?
First I am going to post some example code that does a thing with an ESP32 and MQTT.
   10/17/202 Ambrose Campbell
   Project to display MQTT data on a OLED screen
#include <WiFi.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1351.h>
#include "time.h"
hw_timer_t * timer = NULL;
EventGroupHandle_t eg;
#define evtDoDisplay             ( 1 << 1 )
#define evtCollectHistory        ( 1 << 2 )
#define evtParseMQTT             ( 1 << 3 )
#define evtDoTheAirParticleThing ( 1 << 4 )
// the events in this event groups tasks have been given a delay to avoid a possible race condition.
#define evtGroupBits ( evtCollectHistory | evtDoDisplay | evtDoTheAirParticleThing )
//                                                 CS GPIO_NUM_27, DC GPIO_NUM_12, DIN GPIO_NUM_13, CLK GPIO_NUM_14, RST GPIO_NUM_26
Adafruit_SSD1351 tft = Adafruit_SSD1351( 128, 128, GPIO_NUM_27,    GPIO_NUM_12,    GPIO_NUM_13,     GPIO_NUM_14,     GPIO_NUM_26 );
WiFiClient   wifiClient;
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient );
// black, blue, red, green, cyan, magenta, yellow, white, lightyellow, brown
const int DataCells = 60;
int    ColorPalette[10] = { 0x0000, 0x001F, 0xF800, 0x07E0, 0x07FF, 0xF81F, 0xFFE0, 0xFFFF, 0xFFFFD8, 0xFF8040 };
int    arrayCellPtr = 0;
float  oPressureHistory[DataCells] = {0.0f};
String str_eTopic;
char   strPayload [300] = {NULL};
float  oTemperature = 0.0f;
float  oHumidity = 0.0f;
float  oIAQ = 0.0f; // Indexed Air Quality
float  oPressure = 0.0f;
byte mac[6];
SemaphoreHandle_t sema_HistoryCompleted;
SemaphoreHandle_t sema_MQTT_Parser;;
SemaphoreHandle_t sema_MQTT_KeepAlive;
volatile int iDoTheThing = 0;
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  xSemaphoreTake( sema_MQTT_Parser, portMAX_DELAY);
  str_eTopic = topic;
  int i = 0;
  for ( i; i < length; i++)
    strPayload[i] = ((char)payload[i]);
  strPayload[i] = NULL;
  //log_i( "topic %s payload %s" ,str_eTopicPtr, strPayloadPtr );
  xSemaphoreGive ( sema_MQTT_Parser );
  xEventGroupSetBits( eg, evtParseMQTT ); // trigger tasks
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
void IRAM_ATTR onTimer()
  BaseType_t xHigherPriorityTaskWoken;
  iDoTheThing++;
  if ( iDoTheThing == 60000 )
    xEventGroupSetBitsFromISR( eg, evtGroupBits, &xHigherPriorityTaskWoken );
    iDoTheThing = 0;
  /* Use 4th timer of 4.
    1 tick 1/(80MHZ/80) = 1us set divider 80 and count up.
    Attach onTimer function to timer
    Set alarm to call timer ISR, every 1000uS and repeat / reset ISR (true) after each alarm
    Start an timer alarm
  timer = timerBegin( 3, 80, true );
  timerAttachInterrupt( timer, &onTimer, true );
  timerAlarmWrite(timer, 1000, true);
  timerAlarmEnable(timer);
  str_eTopic.reserve(300);
  eg = xEventGroupCreate();
  tft.begin();
  tft.fillScreen(0x0000);
  sema_MQTT_Parser      = xSemaphoreCreateBinary();
  sema_HistoryCompleted = xSemaphoreCreateBinary();
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_HistoryCompleted );
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  xTaskCreatePinnedToCore( fparseMQTT,      "fparseMQTT",      7000,  NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fCollectHistory, "fCollectHistory", 10000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( MQTTkeepalive,   "MQTTkeepalive",   7000,  NULL, 2, NULL, 1 ); //this task makes a WiFi and MQTT connection.
  xTaskCreatePinnedToCore( fUpdateDisplay,  "fUpdateDisplay",  50000, NULL, 5, NULL, 1 );
} //setup() END
part 2
void GetTheTime()
  char* ntpServer = "2.us.pool.ntp.org";
  int gmtOffset_sec = -(3600 * 7 );
  int daylightOffset_sec = 3600;
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
// http://www.cplusplus.com/reference/ctime/strftime/
int getHour()
  struct tm timeinfo;
  getLocalTime(&timeinfo);
  char _time[ 5 ];
  strftime( _time, 80, "%T", &timeinfo );
  return String(_time).toInt();
void printLocalTime()
  struct tm timeinfo;
  char _time[ 80 ];
  log_i( "%s", _time);
   Collect history information
   task triggered by hardware timer once a minute
void fCollectHistory( void * parameter )
  int StorageTriggerCount = 119;
  bool Tick = true;
  int maxStorageTriggerCount = 120;
  for (;;)
    xEventGroupWaitBits (eg, evtCollectHistory, pdTRUE, pdTRUE, portMAX_DELAY );
    xSemaphoreTake( sema_HistoryCompleted, portMAX_DELAY );
    oPressureHistory[arrayCellPtr] = oPressure;
    StorageTriggerCount++; //triggered by the timer isr once a minute
    log_i( "storage trigger count %d", StorageTriggerCount );
    if ( StorageTriggerCount == maxStorageTriggerCount )
      arrayCellPtr++;
      log_i( "arrayCellPtr %d", arrayCellPtr );
      if ( arrayCellPtr == DataCells )
        arrayCellPtr = 0;
      StorageTriggerCount = 0;
    // log_i( " high watermark %d",  uxTaskGetStackHighWaterMark( NULL ) );
  vTaskDelete( NULL );
} //void fCollectHistory( void * parameter )
void fUpdateDisplay( void * parameter )
  // Color definitions
  // http://www.barth-dev.de/online/rgb565-color-picker/
    ColorPalette[0] = 0x0000; //BLACK
    ColorPalette[1] = 0x001F; //BLUE
    ColorPalette[2] = 0xF800; //RED
    ColorPalette[3] = 0x07E0; //GREEN
    ColorPalette[4] = 0x07FF; //CYAN
    ColorPalette[5] = 0xF81F; //MAGENTA
    ColorPalette[6] = 0xFFE0; //YELLOW
    ColorPalette[7] = 0xFFFF; //WHITE
    ColorPalette[8] = 0xFFFFD8; //LIGHTYELLOW
    ColorPalette[9] = 0xFF8040; //BROWN
  int rowRef = 110;
  int hRef = int( oPressureHistory[0] );
  const int nextPoint = 2;
  int nextCol = 0;
  for (;;)
    xEventGroupWaitBits (eg, evtDoDisplay, pdTRUE, pdTRUE, portMAX_DELAY ); //
    vTaskDelay( 1 );
    tft.fillScreen( ColorPalette[0] );
    tft.setTextColor( ColorPalette[6] );
    tft.setCursor( 0, 25 );
    tft.print( "Temperature: " + String(oTemperature) + "F" );
    tft.setCursor( 0, 35 );
    tft.print( "Humidity " + String(oHumidity) + "%" );
    //set the color of the value to be displayed
    if ( oIAQ < 51.0f )
      tft.setTextColor( ColorPalette[3] );
    if ( (oIAQ >= 50.0f) && (oIAQ <= 100.0f) )
    if ( (oIAQ >= 100.0f) && (oIAQ <= 150.0f) )
      tft.setTextColor( ColorPalette[9] );
    if ( (oIAQ >= 150.0f) && (oIAQ <= 200.0f) )
      tft.setTextColor( ColorPalette[2] );
    if ( (oIAQ >= 200.00f) && (oIAQ <= 300.0f) )
      tft.setTextColor( ColorPalette[5] );
    if ( (oIAQ > 300.0f) )
      tft.setTextColor( ColorPalette[7] );
    // display AQI
    tft.setCursor( 0, 45 );
    tft.print( "AQ Index " + String(oIAQ) );
    tft.setTextColor( ColorPalette[1] ); //set graph line color
    tft.setCursor( 0, 85 );
    tft.print( "Pres: " + String(oPressure) + "mmHg" );
    nextCol = 0;
    for (int i = 0; i <= DataCells; i++)
      int hDisplacement = hRef - int( oPressureHistory[i] ); // cell height displacement from baseline
      tft.setCursor( nextCol , (rowRef + hDisplacement) );
      tft.print( "_" );
      nextCol += nextPoint;
      //place vertical bar representing a 24 hour time period.
      if ( (nextCol % 24) == 0 )
        //tft.drawLine( col, row, width, height, color );
        tft.drawLine( uint16_t(nextCol), uint16_t(120), uint16_t(nextCol), uint16_t(115), ColorPalette[7] );
    // advance cursor to place a begin of graph marker. each letter is 5 spaces wide but graph position marker only advances 2 spaces
    // to keep cursor at begining place cursor +2 the nextCol position.
    tft.setCursor( (arrayCellPtr * nextPoint), (rowRef + 3) );
    tft.print( "I" );
    //     log_i( "fUpdateDisplay MEMORY WATERMARK %d", uxTaskGetStackHighWaterMark(NULL) );
} // void fUpdateDisplay( void * parameter )
    Important to not set vTaskDelay to less then 10. Errors begin to develop with the MQTT and network connection.
    makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
  // setting must be made before the first MQTT connection.
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  for (;;)
    //check for a is connected and if the WiFi thinks its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 250 ); //task runs approx every 250 mS
  vTaskDelete ( NULL );
void connectToMQTT()
  String clientID = String(mac[0]) + String(mac[4]) ;
  log_i( "connect to mqtt clientID %s", clientID );
  while ( !MQTTclient.connected() )
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    log_i( "connecting to MQTT" );
    vTaskDelay( 250 );
  log_i("MQTT Connected");
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( mqtt_topic );
void connectToWiFi()
  log_i( "connect to wifi" );
  while ( WiFi.status() != WL_CONNECTED )
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    log_i(" waiting on wifi connection" );
    vTaskDelay( 4000 );
  log_i( "Connected to WiFi" );
  WiFi.macAddress(mac);
  log_i( "mac address %d.%d.%d.%d.%d", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]  );
  WiFi.onEvent( WiFiEvent );
  GetTheTime();
  printLocalTime();
void fparseMQTT( void *pvParameters )
  for (;;)
    xEventGroupWaitBits (eg, evtParseMQTT, pdTRUE, pdTRUE, portMAX_DELAY ); //
    xSemaphoreTake( sema_MQTT_Parser, portMAX_DELAY );
    if ( str_eTopic == topicOutsideTemperature )
      oTemperature = String(strPayload).toFloat();
    if ( (String)str_eTopic == topicOutsideHumidity )
      oHumidity = String(strPayload).toFloat();
    if ( (String)str_eTopic == topicAQIndex )
      oIAQ = String(strPayload).toFloat();
    if ( String(str_eTopic) == topicOutsidePressure )
      oPressure = String(strPayload).toFloat();
    // clear pointer locations
    memset( strPayload, NULL, 300 );
    str_eTopic = ""; //clear string buffer
    xSemaphoreGive( sema_MQTT_Parser );
} // void fparseMQTT( void *pvParameters )
void loop() { }
Note how the network and MQTT connection are made and maintained.
The task void fparseMQTT( void *pvParameters ) is where you can stop and start the light shows based on received info.
Each light show can be its own task that is ran, triggered, by the received MQTT info.
client.loop() is what is used to receive messages and trigger the callback routine so messages can be received. It is very important, especially when an app needs to receive messages, to run client.loop() as much as reasonably possible. That's why the MQTT keep alive runs as its own self triggering task. When the client loop() runs it is important that no other publishing task be in operation during the client.loop(). You can see a semaphore wrapping the client.loop(). The client.loop() task will wait for its own semaphore token, in this case there can only be one. When all other publishing tasks are done, a semaphore becomes available for client loop to do its thing. During client.loop() all other publishing tasks are held in abeyance until client.loop() is completed.
You may be able to see, from the above description, that separating out rainbow and full color into separate tasks, with the use of a semaphore, the tasks can be controlled from the MQTT parser, which receives messages from the MQTT Broker and, thusly, responding quickly to received instructions.
I'd use one semaphore for the rainbow task and one for the full color. If the mqtt parser receives the message to stop all then take both semaphores in the parser, if the message is to run rainbow task then take full color semaphore and give rainbow semaphore, and if message run full color, give full color semaphore and take rainbow semaphore.
Hence, my question is: How would go about running a loop in which LED's change and have it be interrupted solely by an MQTT message?
You could use an event trigger, or a semaphore, or a message; such as a variable with the proper message, to either the rainbow task or full color mode task to stop.
Just thinking out loud.
TaskA and TaskB and TaskParse and semaTaskA and semaTaskB
taskA(){
wait for semaTaskA
do the light show
give semaphore semaTaskA
taskB(){
wait for semaTaskB
do the light show
give semaphore semaTaskB
TaskParse()
message received run rainbow
wait for semaTaskB
give semaTaskA
message received run full color
wait for semaTaskA
give semaTaskB
The MQTT keep alive runs in its own thread on its own time and separately from the light show task.
Hey,
thanks for all your replies, although I think using semaphores for this is too complicated for such a small project.
What I ended up doing (and it worked) is I added a client.loop() inside of the rainbow() function, and then when it is triggered (when an MQTT message arrives), I changed the colorID, which basically tells the whole program what to display on the LED’s. So I also added an if statement in the rainbow() function to check whether or not it’s “his” turn to display.
The whole code stays the same, so I’m just posting the rainbow() function here:
void rainbow() {
      if (colorID != 6) return;
      client.loop();
    strip.show();
    delay(10);
