I have two different codes. One uses a switch statement for 3 cases whereas I converted the first code into the second code to use "IF" statements.
What I have is an IR receiver that gives an input to my Arduino which then gives two outputs (step and dir). Step controls whether the stepper motor is on/off and dir controls left/right. I get the code working using the switch case, but when I tried using the If case nothing happens. The code uploaded just fine. No error. So I'm not sure what I did wrong.
What I am trying to do is to get the motor code working using the if statements, that way I can add in an additional if statement that will interrupt the motor code. So it would look something like this:
If button 1 is pressed, rotate 3600 degrees. If button 2 is pressed while still rotating, stop the motor.
#include <IRremote.h>
#define button1 16582903
#define button2 16615543
#define button3 16599223
#define RECV_PIN 10
IRrecv irrecv(RECV_PIN);
decode_results results;
long lReceived = 0 ;
#define DIR_PIN 2
#define STEP_PIN 3
pinMode(DIR_PIN, OUTPUT);
pinMode(STEP_PIN, OUTPUT);
pinMode(RECV_PIN , INPUT);
irrecv.enableIRIn(); // Start the receiver
void loop(){
if (irrecv.decode(&results)) {
lReceived = results.value ;
switch (lReceived) {
case button1:
digitalWrite (STEP_PIN, HIGH);
digitalWrite (DIR_PIN, HIGH);
//rotate a specific number of degrees
rotateDeg(3600, .5);
case button2:
digitalWrite(STEP_PIN, LOW);
digitalWrite( DIR_PIN, HIGH);
case button3:
digitalWrite( STEP_PIN, HIGH);
digitalWrite( DIR_PIN, LOW);
rotateDeg(-3600, .5); //reverse
irrecv.resume(); // Receive the next value
void rotateDeg(float deg, float speed){
//rotate a specific number of degrees (negitive for reverse movement)
//speed is any number from .01 -> 1 with 1 being fastest - Slower is stronger
int dir = (deg > 0)? HIGH:LOW;
digitalWrite(DIR_PIN,dir);
int steps = abs(deg)*(1/0.225);
float usDelay = (1/speed) * 70;
for(int i=0; i < steps; i++){
digitalWrite(STEP_PIN, HIGH);
delayMicroseconds(usDelay);
#define RECV_PIN 10
long Received = 0 ;
#define DIR_PIN 2
#define STEP_PIN 3
void loop(){
if (Received==button1){
if (Received==button2){
if (Received==button3){
