Hello, I have made two modules, module1 gets HC-12 signal from the module2, and the module2 gets proximity sensor input, when sensor touches something, Interrupt gets ground signal, and it triggers arduino to send a signal to module1.
Using arduino UNO, and HC-12 module.
My problem is that every time module1 is turned ON, Interrupt gets some noise, (I think it is the electromagnetic signal from HC-12) and Interrupt gets activated (LOW), although it is not real.
This has been driving me crazy for the last week.
I am trying to use pulseIn() to filter out, very short noise, but I don't know why I can't get correct result.
How can I filter this noise, by using software? for example, software debouncer?
(1) Module1 code
#include <SimpleTimer.h>
#include <SoftwareSerial.h>
#define IDlen 4
#define maxID 5
SoftwareSerial mySerial(2,3);
LiquidCrystal_I2C lcd(0x27, 16, 2);
int upButtonPin = 7;
int selectButtonPin = 6;
int downButtonPin = 5;
int sensors[maxID] = {1001,9999,9999,9999,9999};
int receivedID = 0;
int currentPos = 0;
String rcvMsg = "xxxx";
//void printSensor(int intID);
void menu();
void showAllSensors();
int removeID(int senNumInt);
Serial.println("Serial began.");
mySerial.begin(9600);
// mySerial.println("0000");
lcd.begin();
pinMode(upButtonPin, INPUT_PULLUP);
pinMode(selectButtonPin, INPUT_PULLUP);
pinMode(downButtonPin, INPUT_PULLUP);
rcvMsg = "xxxx";
lcd.setCursor(1,1);
lcd.clear();
lcd.print("Ready");
if(digitalRead(upButtonPin)==LOW){
lcd.clear();
lcd.print("Up btn pressed!");
if(digitalRead(downButtonPin)==LOW){
lcd.clear();
lcd.print("Down btn pressed!");
if(digitalRead(selectButtonPin)==LOW){
lcd.clear();
lcd.print("Registered sensors:");
lcd.clear();
showAllSensors();
menu();
if(mySerial.available()>0){
// String rcvMsg = mySerial.readStringUntil('\n');
Serial.print("Received msg: ");
Serial.print(rcvMsg);
Serial.print('\n');
receivedID = rcvMsg.substring(0,4).toInt();
Serial.println(receivedID);
delay(50);
for (int i=0;i<maxID;i++){
if(sensors[i] == receivedID){
String temp = String(receivedID);
String ack = String(temp + "01"); // 01: success 02: reject (ID does not exist)
mySerial.println(ack);
Serial.print("Ack sent: ");
Serial.print(ack);
void menu(){
lcd.print("UP: add sensor");
lcd.setCursor(0,1);
lcd.print("DOWN: del sensor");
lcd.setCursor(0,0);
while(1){
lcd.clear();
lcd.print("Add sensor:");
delay(1500);
lcd.clear();
int senNumInt = 1000;
char senNum[IDlen];
sprintf(senNum, "%d", senNumInt);
while(1){
lcd.print(senNum);
senNumInt++;
lcd.clear();
lcd.print(senNum);
senNumInt--;
lcd.clear();
lcd.print(senNum);
lcd.clear();
lcd.print(senNum);
lcd.setCursor(0,1);
lcd.print("Menu: OK, Down: Cancel");
//센서 입력값을 받아서, 리스트에 넣어 놓기
sensors[currentPos] = senNumInt;
lcd.clear();
showAllSensors();
delay(1500);
break; // 값 입력 후 저장한 것 보여주고... 나가기.
delay(200);
lcd.clear();
delay(200);
} // up button 누름 메뉴 끝
lcd.clear();
lcd.print("Remove sensor:");
delay(1500);
lcd.clear();
char senNum[IDlen];
while(1){
lcd.print(senNum);
senNumInt++;
lcd.clear();
lcd.print(senNum);
senNumInt--;
lcd.clear();
lcd.print(senNum);
lcd.clear();
lcd.print(senNum);
lcd.setCursor(0,1);
lcd.print("Delete sensor");
delay(600);
lcd.clear();
//센서 입력값을 받아서, 리스트에서 찾은 후 삭제
int result = removeID(senNumInt);
if(result==1){
lcd.print("Deleted.");
showAllSensors();
}else{
lcd.print("No such ID!!");
delay(1500);
delay(200);
lcd.clear();
delay(200);
} // down button 누름 메뉴 끝
delay(200);
return;
void showAllSensors(){
char imsi[IDlen];
for(int i=0;i<maxID;i++){
Serial.println(sensors[i]);
sprintf(imsi, "%d", sensors[i]);
lcd.print(imsi);
delay(800);
lcd.clear();
return;
int removeID(int senNumInt){
int isFound = 0;
if(sensors[i] == senNumInt){
sensors[i] = 9999;
isFound = 1;
return isFound;
(2) module2 code
#include <avr/sleep.h>
SimpleTimer timer;
const int wakeUpPin = 2; // pin of interrupt 0
const int LED = 8;
const int numMsg = 1; // For the safety, send multiple messages, everytime.
boolean armed = false;
SoftwareSerial mySerial(4,5);
String ID = "1001";
String code = "01";
String msg = "xxxx";
int timerID = 0;
boolean isWaked = false;
int pulseWidth = 0;
Communication protocol
01: powered on
02: Sensor touched (Feed is full)
03: alive
String msg = String(ID + code);
pinMode(wakeUpPin, INPUT_PULLUP);
pinMode(LED, OUTPUT);
timerID = timer.setInterval(1000, sendMsg);
Serial.println(msg);
delay(100);
void loop() // 반복
pulseWidth = pulseIn(wakeUpPin, LOW, 100000);
Serial.println("start loop.");
armed = true;
delay(100);
Serial.println("Now sleeping..");
delay(200);
sleepNow();
Serial.println(pulseWidth);
if(armed){
Serial.println("Waked up. Send Feed full msg.");
delay(200);
code = "02";
sendMsg();
int count = 0;
while(1){
count++;
if(count>200){ //prevent infinite loop
count = 0;
Serial.print('*');
Serial.println("RECEIVED!!!!");
if(rcvMsg.substring(0,4).equals(ID)){
// timer.deleteTimer(timerID);
Serial.println("My msg is received successfully. Now sleep again..\n");
delay(50);
armed = false;
void wakeUpNow(){
isWaked = true;
return;
void sleepNow(){
Serial.println("Entered sleep now()");
delay(100);
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
attachInterrupt(0,wakeUpNow, LOW);
sleep_mode();
// When wakes up, resume codes from here.
sleep_disable();
detachInterrupt(0);
return;
void sendMsg(){
for (int i=0;i<numMsg;i++){
mySerial.println(msg);
return;
