Interrupt not working on Leo
hi there I can not seem to get the Interrupt on pin 7 on the leo to work,I have this as a test code and it seems to work fine on pin 2 and 3, any ideas?
const byte LED = 13; const byte BUTTON = 7;
// Interrupt Service Routine (ISR) void pinChange () { if (digitalRead (BUTTON) == HIGH) digitalWrite (LED, HIGH); else digitalWrite (LED, LOW); } // end of pinChange
void setup () { pinMode (LED, OUTPUT); // so we can update the LED pinMode (BUTTON, INPUT); digitalWrite(BUTTON, HIGH); // turns the pullup on attachInterrupt (4, pinChange, CHANGE); // attach interrupt handler } // end of setup
void loop () { // loop doing nothing }
Which version of the IDE do you have? It looks to me like 1.0.3 does not implement attachInterrupt (4 ...) for the ATmega32U4 however 1.0.5 does.
Ah!
Mark
I am using 1.0.1 so that might be where my problem is I will have a go with 1.0.5
Hi Leo,
I have a same problem with UNO SMB R2
I tried to test with the reference’s example, and I hope the interrution is run several times.
The test is as follows :
int pin = 13;
volatile int state = LOW;
pinMode(pin, OUTPUT);
attachInterrupt(0, blink, RISING);
digitalWrite(pin, state);
void blink()
state = !state;
The shema in file attach.
What problem do you have ? The program and schematic look OK to me, but each button press may produce several interrupts due to the contacts bouncing.
Hi UKHeliBob,
That's what I thought, but when i watching with osciloscope, I don't see the contacts bouncing. It Is possible to put a filter on the input to be sure there is no bounce? thank you
Yes create a hardware debouncing circuit like this
This eliminate some spikes and the output is almost a perfect square wave
