Hello boys & girls.
When i use the code below on a standart Arduino Uno, it works just fine. When i move it to a standalone Atmega 644p or 1284p, it does no longer count the rpm. I have set the hall sensor pin to pin 0. I also tried pin 1, 2, 3 & 4 - no luck.
Its compiled in IDE 0023, as a Sanguino 644p or 1284p (tried both chips).
I have hooked AGnd up to Gnd and AVCC to VCC and AREF to GND through a 100nf cap.
Do you see any errors in the code below or is it on the hardware side i need to look.
Thnk you for your help!!
//code by Crenn from http://thebestcasescenario.com
//project by Charles Gantt from http://themakersworkbench.com
/*To
disable interrupts:
cli(); // disable global interrupts
and to enable them:
sei(); // enable interrupts
#include <LiquidCrystal.h>
LiquidCrystal lcd(26, 27, 28, 29, 30, 31);
int NbTopsFan; //Varibles used for calculations
int Calc;
//The pin location of the sensor
int hallsensor = 0;
int alarm1 = 13; // alarm output 1 (pin 8)
typedef struct{ //Defines the structure for multiple fans and their dividers
char fantype;
unsigned int fandiv;
}fanspec;
//Definitions of the fans
fanspec fanspace[3]={{0,1},{1,2},{2,8}};
char fan = 1; //This is the varible used to select the fan and it's divider, set 1 for unipole hall effect sensor
//and 2 for bipole hall effect sensor
void rpm () //This is the function that the interupt calls
NbTopsFan++;
//This is the setup function where the serial port is initialised,
//and the interrupt is attached
pinMode(alarm1, OUTPUT);
lcd.begin(16, 2);
pinMode(hallsensor, INPUT);
attachInterrupt(0, rpm, RISING);
lcd.begin(16, 2);
void loop ()
NbTopsFan = 0; //Set NbTops to 0 ready for calculations
sei(); //Enables interrupts
delay (500); //Wait 0,5 second
cli(); //Disable interrupts
Calc = ((NbTopsFan * 120)/fanspace[fan].fandiv); //Times NbTopsFan (which is apprioxiamately the fequency the fan is spinning at) by 60 seconds before dividing by the fan's divider
Serial.print (Calc, DEC); //Prints the number calculated above
Serial.print (" RPM\r\n"); //Prints " rpm" and a new line
lcd.setCursor(0,1); //set cursor upper left corne
lcd.print (Calc, DEC); //Prints the number calculated above
lcd.print (" RPM "); //Prints " rpm" and a new line
if (Calc <= 1000) {
digitalWrite (alarm1, HIGH);
}else{
digitalWrite (alarm1, LOW);
