Hi guys,
Sorry if this is the wrong forum or if this question has been asked previously. I’ve been scratching my head for a couple of days now on this one with no luck in searching for any answers to a similar problem.
So here it is. I’m trying to get a momentary button to change what patterns I’m using in a music visualizer I have made. I’m trying to do this using an interrupt to run through a switchcase. I’ve had this work on previous projects and even cross referencing them I can’t see where I’m going wrong.
I’d be over the moon if anybody here can help.
Here’s the code.
#include <Audio.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <FastLED.h>
#define DATA_PIN 1
#define CLK 2
#define LED_COUNT 100
#define bright 240
#define sensitivity 0.25 // 0.01 - 0.2
//AUDIO//
const int myInput = AUDIO_INPUT_LINEIN;
AudioInputI2S audioInput; // audio shield: mic or line-in
AudioAnalyzeFFT1024 myFFT;
AudioOutputI2S audioOutput; // audio shield: headphones & line-out
AudioConnection patchCord1(audioInput, 0, myFFT, 0);
AudioControlSGTL5000 audioShield;
//LEDS//
struct CRGB leds[LED_COUNT];
//INTERRUPT//
int int0 = 3;
volatile int state = 0;
AudioMemory(12);
audioShield.enable();
audioShield.inputSelect(myInput);
audioShield.volume(0.5);
myFFT.windowFunction(AudioWindowHanning1024);
attachInterrupt(int0,butStateChange,CHANGE);
LEDS.addLeds<WS2801, DATA_PIN, CLK, RGB>(leds, LED_COUNT);
for(;;) {
switch (state){
case 0: {
bars();
case 1:{
square();
void loop(){
void butStateChange()
static unsigned long last_interrupt_time = 0;
unsigned long interrupt_time = millis();
// If interrupts come faster than 200ms, assume it's a bounce and ignore
if (interrupt_time - last_interrupt_time > 200)
state++;
if (state >1){
state=0;
last_interrupt_time = interrupt_time;
