Interrupt Routines within Bluetooth
Hello,
I am using a Seeed Bluetooth shield (http://www.seeedstudio.com/wiki/Bluetooth_Shield) on my Arduino Due. So far I have had success connecting to a PC and sending data from the Arduino in my main program loop. However, for the project I am working on, I need to send data at a 1kHz rate. I have done this by setting up a timer compare interrupt to fire every millisecond.
My problem is that when I upload the sketch, the Bluetooth shield has to establish a connection first and I think the interrupt is messing up the system somehow. The shield has some indicator lights that flash for different statuses (Alternating red and green LED blinking = device inquirable, 2 flashes of green LED/second = Idle state, 1 flash green LED/sec = Active state). When I upload the sketch, the shield will only blink for about 4 seconds until the lights turn off completely and do nothing from then on out. I have tried to open the COM port I am using but it won't open (the Arduino isn't connected I am assuming).
In the setup loop there is a "setupBlueToothConnection" function for the shield. I disabled global interrupts so the interrupt wouldn't get in the way, but haven't had any luck.
I wrote another sketch using the same interrupt to send data to the PC over a USB serial connection and the program works fine.
I was hoping you guys would have some ideas of what I could do to fix this issue.
Cheers!
You are going to want to post your code so that we can read over it.
This is the basic task I want to do. A timer interrupt occurs at a ~1k rate where it reads the pin and outputs the reading. I have been able to do this over the USB serial connection so I know the logic works. It is when I try to use my Bluetooth shield that I have issues.
Thanks!
#include <SoftwareSerial.h>   //Software Serial Port
#define RxD 6
#define TxD 7
#define DEBUG_ENABLED  1
SoftwareSerial blueToothSerial(RxD,TxD);
#include "avr/pgmspace.h"
#include <avr/io.h>
#include <avr/interrupt.h>
int sensorVoltage = 0;
  pinMode(2, OUTPUT);   //Notch Filter
  pinMode(3, OUTPUT);   //Pre Charge
  pinMode(4, INPUT);    //Gain
  pinMode(RxD, INPUT);  //Receiver
  pinMode(TxD, OUTPUT); //Transmitter
  setupBlueToothConnection();
  /* initialize Timer1 */
  cli();		/* disable global interrupts */
  TCCR1A = 0;		/* set entire TCCR1A register to 0 */
  TCCR1B = 0;		/* same for TCCR1B */
  /* set compare match register to desired timer count: */
  OCR1A = 15999;	/* with a 16 MHz clock, this will give about 1KHz interrupt */
  /* turn on CTC mode: */
  TCCR1B |= (1 << WGM12);
  TCCR1B |= (1 << CS10);  /* Set CS10 bit for 1023 no prescaler: */
  TIMSK1 |= (1 << OCIE1A);
  sei(); /* enable global interrupts: */
ISR(TIMER1_COMPA_vect)
     sensorVoltage = analogRead(A0);
     blueToothSerial.println(sensorVoltage);
     blueToothSerial.flush()
  while(1)
    //DO NOTHING
void setupBlueToothConnection()
  blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
  blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
  blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); //set the bluetooth name as "SeeedBTSlave"
  blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
  blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
  delay(2000); // This delay is required.
  blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
  Serial.println("The slave bluetooth is inquirable!");
  blueToothSerial.flush();
A quick look at the link you supplied and it shows a switch that allows the BT modules connect status to be read on A1
PIO1 Status instruction port of Bluetooth module can be read by Arduino A1 port: low-disconnected, high-connected.
In setup before doing the interrupt setup code wait for a connection.
You should not be doing serial print or flush within an ISR.
Do I do this by making the setupBluetoothConnection() return a value and not starting the timer initialization until that setup is complete?
How else besides ISRs could I make the data print at the rate I want it to?
Why are you running an infinite loop inside an infinite loop? Looks a trifle stupid to me.
The blink without delay example would show that interrupts are not needed at all.
