interrupt service is dumping garbage values to LCD
#include <SPI.h>
#include <PN532_SPI.h>
#include "PN532.h"
#include <LiquidCrystal.h>
PN532_SPI pn532spi(SPI, 10);
PN532 nfc(pn532spi);
LiquidCrystal lcd(4,5,0,6,7,8);
static uint8_t selected_option = 0;
#define LED0 17
#define LED1 18
#define LED2 19
boolean TurnDetected;
boolean up;
const int PinCLK=2; // Used for generating interrupts using CLK signal
const int PinDT=3; // Used for reading DT signal
//const int PinSW=4; // Used for the push button switch
void initEncoder(void) {
/* Setup encoder pins as inputs */
pinMode(PinCLK,INPUT);
pinMode(PinDT,INPUT);
attachInterrupt (0,isr,FALLING); // interrupt 0 is always connected to pin 2 on Arduino UNO
Serial.begin (9600);
Serial.println("Start");
Initialize pins for LEDs
void initLED(void) {
pinMode(LED0, OUTPUT);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
digitalWrite(LED0, LOW);
digitalWrite(LED1, LOW);
digitalWrite(LED2, LOW);
syncLED();
void initNFC(void) {
nfc.begin();
lcd.clear();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
// Got ok data, print it out!
lcd.print("found board");
Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
// Set the max number of retry attempts to read from a card
// This prevents us from waiting forever for a card, which is
// the default behaviour of the PN532.
nfc.setPassiveActivationRetries(0xFF);
// configure board to read RFID tags
nfc.SAMConfig();
Serial.println("Waiting for an ISO14443A card");
void isr () { // Interrupt service routine is executed when a HIGH to LOW transition is detected on CLK
if (digitalRead(PinCLK))
up = digitalRead(PinDT);
up = !digitalRead(PinDT);
TurnDetected = true;
void uid_output(void) {
uint8_t uidReadCount=0;
boolean success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
lcd.clear();
if (success) {
//Serial.println("Found a card!");
//Serial.print("UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
if (uidLength == 7) {
Serial.print(" ");
for (uint8_t i=0; i < uidLength; i++)
if (uid <= 0x0F) { Serial.print(" 0x0");lcd.print(" 0x0"); }
else { Serial.print(" 0x"); lcd.print(" 0x");}Serial.print(uid_, HEX);lcd.print(uid*,HEX);Serial.print(",");lcd.print(",");
Serial.println(""); lcd.print("");
//Beep to indicate tag was read*
* // tone(PIEZO_PIN, NOTE_G5, 180);*
// lcd.setCursor(0,1);
* // lcd.clear();
// lcd.print(++uidReadCount);*_
* //Serial.print("UID Value: ");*
* //for (uint8_t i=0; i < uidLength; i++)
_ //{
// Serial.print(" 0x");Serial.print(uid, HEX);
//Serial.println("");
// Wait 1 second before continuing*
* delay(1000);
else*
// PN532 probably timed out waiting for a card*
* //Serial.println("Timed out waiting for a card");
void syncLED(void) {
digitalWrite(LED2, LOW);_
switch(selected_option) {
_ case 0:
digitalWrite(LED0, HIGH);
case 1:
digitalWrite(LED1, HIGH);
case 2:
digitalWrite(LED2, HIGH);
Increments the voting selection*
void incSelOpt(void) {
* if (++selected_option > 2) { selected_option = 0; }*
* syncLED();
* Decrements the voting selection*
void decSelOpt(void) {
* //Postfix checks before decrement*
* if (selected_option-- == 0 ) { selected_option = 2; }*
* syncLED();
lcd.begin(20,4); // put your setup code here, to run once:
initEncoder();
initLED();
initNFC();
if (TurnDetected) { // do this only if rotation was detected*
* if (up)
incSelOpt();
else*
* decSelOpt();
TurnDetected = false; // do NOT repeat IF loop until new rotation detected*
* Serial.print ("Count = "); _
//lcd.print(selected_option,DEC);
Serial.println (selected_option);
_}
uid_output();
}*_
Maybe the Arduino doesn't like italics
And the forum experts don't like code with no description of the problem.
Does it work when you don't attach the ISR? What other changes did you make from the last time it was working? Can you post a copy of the code that did work?
Garbage on the LCD, you say?
No wonder with this set of pins:
Also, something missing here, considering that these are used in an interrupt handler:
boolean up;
