I’m relatively new to Arduino and I am working on a project. I want to make a wakeup light.
Therefore, I built an arduino controlled light dimmer (see http://www.instructables.com/id/Arduino-controlled-light-dimmer-The-circuit/ and Arduino Real Time Clock (RTC) Tutorial using DS1307)
I’ve also tried different RTC libraries. But the thing is my ISR crashes and nothing happens anymore.
I’m using the uno and nano. Both crash.
Can you please help me?
#include <RTClib.h>
#include <Time.h>
#include <Wire.h>
const uint8_t AC_LOAD = PD3; // Output to Opto Triac pin
uint8_t dimming = 128; // Dimming level (0-128) 0 = ON, 128 = OFF
const char *monthName[12] = {
"Jan", "Feb", "Mar", "Apr", "May", "Jun",
"Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
const uint8_t tl_load = 0;
const uint16_t tl_comp = 31250;
RTC_DS1307 rtc;
char daysOfTheWeek[7][12] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
Serial.println("setup");
// initialize timer1
// Serial.println("Disable timer interrupts.");
// noInterrupts(); // disable all interrupts
// Serial.println("Timer interrupts disabled.");
// reset Timer1 control Reg A
TCCR1A = 0;
// set to prescaler of 256
TCCR1B |= (1 << CS12);
TCCR1B &= ~(1 << CS11);
TCCR1C &= ~(1 << CS10);
// reset Timer1 and set compare value
TCNT1 = tl_load;
OCR1A = tl_comp;
//enable timer1 compare interrupt
TIMSK1 = (1 << OCIE1A);
//enable global interrups
sei();
if (! rtc.begin())
Serial.println("Couldn't find RTC");
while (1);
if (! rtc.isrunning())
Serial.println("RTC is NOT running!");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));//auto update from computer time
//rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));// to set the time manualy
while (!Serial) ; // wait for serial
delay(200);
pinMode(AC_LOAD, OUTPUT);// Set AC Load pin as output
attachInterrupt(digitalPinToInterrupt(PD2), zero_crosss_int, RISING); // Choose the zero cross interrupt # from the table above
ISR(TIMER1_COMPA_vect) // interrupt service routine
Serial.println("ISR start");
TCNT1 = tl_load;
printTime();
Serial.println("ISR done");
void zero_crosss_int()
//function to be fired at the zero crossing to dim the light
//the interrupt function must take no parameters and return nothing
// Firing angle calculation : 1 full 50Hz wave =1/50=20ms
// Every zerocrossing thus: (50Hz)-> 10ms (1/2 Cycle)
// For 60Hz => 8.33ms (10.000/120)
// 10ms=10000us
// (10000us - 10us) / 128 = 75 (Approx) For 60Hz =>65
int dimtime = (75*dimming); // For 60Hz =>65
delayMicroseconds(dimtime); // Wait till firing the TRIAC
digitalWrite(AC_LOAD, HIGH); // Fire the TRIAC
delayMicroseconds(10); // triac On propogation delay
// (for 60Hz use 8.33) Some Triacs need a longer period
digitalWrite(AC_LOAD, LOW); // No longer trigger the TRIAC (the next zero crossing will swith it off) TRIAC
for (int i=128; i >= 15; i--){
dimming= i;
delay(70);
void printTime(){
DateTime now = rtc.now();
Serial.print(now.hour());
Serial.print(':');
Serial.print(now.minute());
Serial.print(':');
Serial.println(now.second());
