Hello, I wrote this code:
int sw1Pin=2;
int sw2Pin=3;
int jmpr1Pin=5;
int jmpr2Pin=8;
int add1Pin=4;
int add2Pin=7;
int add01Pin=6;
int add02Pin=9;
int lightPin=11;
int offDelay=15000;
int ledState=0;
int ledDim=0;
volatile int offCount=0;
volatile bool swState;
bool prevSwState=0;
bool fadeFlag=0;
int myDelay2 = 5; // Wait this many millis()
int lastTime = 0; // The clock time in millis()
int deltaT; // A calculated value
int lastTime2=0;
int deltaT2;
pinMode(lightPin,OUTPUT);
pinMode(add01Pin,OUTPUT);
pinMode(add02Pin,OUTPUT);
pinMode(add1Pin,OUTPUT);
pinMode(add2Pin,OUTPUT);
pinMode(13,OUTPUT);
digitalWrite(add01Pin, LOW);
digitalWrite(add02Pin, LOW);
digitalWrite(add1Pin, HIGH);
digitalWrite(add2Pin, HIGH);
pinMode(sw1Pin,INPUT_PULLUP);
pinMode(sw2Pin,INPUT_PULLUP);
pinMode(jmpr1Pin,INPUT);
pinMode(jmpr2Pin,INPUT);
if(digitalRead(jmpr1Pin)==HIGH)offDelay+=15000;
if(digitalRead(jmpr2Pin)==HIGH)offDelay+=30000;
//Serial.begin(9600);
attachInterrupt(digitalPinToInterrupt(sw1Pin),doorAction,CHANGE);
attachInterrupt(digitalPinToInterrupt(sw2Pin),doorAction,CHANGE);
//Serial.print(swState);
//Serial.print(" ");
//Serial.print((offCount>0)&&(swState==0));
//Serial.println();
if ((swState==1)&&(ledState==0))fade();
else{
if((swState==0)&&(ledState==1)){
while((offCount>0)&&(swState==0)){
deltaT2=millis()-lastTime2;
if(deltaT2>=1){
offCount--;
//if(((offCount%500)<=25)&&(offCount>1))digitalWrite(13,HIGH);
//else digitalWrite(13,LOW);
lastTime2=millis();
if((swState==0)&&(ledState==1))fade();
void doorAction(){
swState=(digitalRead(sw1Pin))||(digitalRead(sw2Pin));
//digitalWrite(13,swState);
//Serial.println(swState);
if(swState==0)offCount=offDelay;
void fade (){
if(ledState==1)
{ while(ledDim>0){
deltaT = millis() - lastTime;
if ( deltaT >= myDelay2 ) {
ledDim--;
analogWrite(lightPin,ledDim);
lastTime = millis();
ledState=0;
{ while(ledDim<255){
ledDim++;
ledState=1;
It's purpose is to detect the state of 2 doors and turn on (fade in/out) LED strip using an N-MOSFET.
- I need the LED strip to turn on(linear fade on) when one or both doors open
- While door(s) is (are) open, the LED strip should stay lit
- When both doors are closed, a countdown of 15s(or more, defined by additional jumpers) should start and if during the countdown both of the doors stay closed, the LED strip should turn off (linear fade off)
The circuit works normally when I restart the Nano and try to open and close the door a few times.
The problem is, when I leave both doors closed for some time, like 10 minutes or more, the Arduino freezes and doesn't turn on the LED strip anymore.
attached below is a rough schematic of the circuit.
Please ignore unused variables as I'm used to Eclipse so I forgot to remove them
Any help would be appreciated
